Re: BB Superchargers. Any fit?
[Re: V194]
#2070917
05/10/16 06:26 PM
05/10/16 06:26 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Underhood of what?
Pretty sure nothing Roots based will fit, unless it's in a truck of some sort and even then.
[Re: Supercuda]
#2070961
05/10/16 07:30 PM
05/10/16 07:30 PM
Posts: 3,110 SC
V194
SC
Underhood of what?
B, E or C bodies.
[Re: V194]
#2070983
05/10/16 08:02 PM
05/10/16 08:02 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
No roots or screw type blowers will fit under the hood of a 60s-70s car when mounted on a V8. You can probably fabricate some sort of valley cover and intake to use with an EFI system but you're on your own. A blower under the hood will have to be centrifugal. Personally, I prefer turbos.
[Re: V194]
#2071002
05/10/16 08:25 PM
05/10/16 08:25 PM
Supercuda
About to go away
About to go away
up yours
You might have room under the hood of a C body to remote or front mount a roots type and duct the output thru a normal carb/intake setup. But that'd be "interesting" to say the least
[Re: feets]
#2071073
05/10/16 10:05 PM
05/10/16 10:05 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
There was a company in Australia that was building a whipple style top mount kit for the 426 Hemi... with a low profile air cleaner it fit under the hood of a Challenger at least (the main test car they used) There were various issues with the setup though and it never really went any where...
[Re: Mr.Yuck]
#2071341
05/11/16 10:34 AM
05/11/16 10:34 AM
Supercuda
About to go away
About to go away
up yours
Baring the procharger type or Paxton type. Anything else?
[Re: Supercuda]
#2071372
05/11/16 11:45 AM
05/11/16 11:45 AM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Baring the procharger type or Paxton type. Anything else? NO.... a small 471 would fit under a hood with a small scoop however it is pretty small for a 440.
[Re: bobby66]
#2071535
05/11/16 04:44 PM
05/11/16 04:44 PM
RapidRobert
I'm strickly WAG ing here but the post reminded me of the "Magnacharger" supercharger kits of decades ago (iirc hood clearance was its bennie that was touted in addition to unGodly airflow/power output. It come out sideways on eac side as opposed to straight up like a Roots & dipped down and had 2 side draft? Dellorto carbs (also iirc). If I was to do one at first blush I'd go with the Paxton like what was pictured but I would definitely get familiar with the supercharged sites to gain some knowledge as I'm a newer than new newbie. I remember a quote in Hot Rod decades ago stating "that you are not ready for the power"
[Re: V194]
#2071592
05/11/16 06:33 PM
05/11/16 06:33 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
Nitrous A Kenne-Bell or Whipple would be nice if someone made an intake for a 440.
[Re: V194]
#2071941
05/12/16 10:29 AM
05/12/16 10:29 AM
Mr.Yuck
Brookeville, Md
Why I asked about "other than" kits was that from what I can see there is little room for A/C and PS with a Procharger type system. Now I have checked the supercharger store and IMO they are way out there on pricing. All of the Magnacharger types I see today are from late model HEMI only? So if you have a big block (440+) and want to make some decent power (700+ HP) and have it reliable and live on the street we can go turbo or supercharger. I cant see any other way to get to the HP goal. Thoughts? Buy a kit for a BB Chevy and modify it. That will save you thousands. You can relocate your alternator and use a small GM unit. I ditched my PS unit and but my battery in the trunk. You would want to mount it in the passenger side. One thing you also might want to do is ditch the big-old factory ac compressor and go with a small modern unit. That will free up a bunch of space.
[Re: Mr.Yuck]
#2072146
05/12/16 05:55 PM
05/12/16 05:55 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
I don't normally think of the words "Roots Supercharger" and "reliable and live on the street" all in the same sentence. I certainly get the desire for horsepower thing though.
I’m listening.
