Thumbs up for "the right stuff" Permatex gasket maker #2069878
05/09/16 02:51 AM
05/09/16 02:51 AM
RapidRobert Offline OP
I gotta give a shout out for this stuff. it sealed a temp sender into the intake that Indian head would not seal (tho it is pipe threads and in all fairness pipe dope may have sealed it but I was out) but the sender into the adapter ain't NPT and the stat housing that would not seal after multiple attempts (including drawfiling it flat (& a new one from NAPA) & on that it even took TRS gasket maker PLUS the gasket! On a side note the NAPA housing has a straight flange/no barb on the end like the OE Mopar one, I highly suggest filing a wide groove in it (I got a hot antifreeze bath in the middle of this ordeal!). All good (in the hood) now
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: RapidRobert] #2069967
05/09/16 11:04 AM
05/09/16 11:04 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Yep, that stuff is great! Until you want to take it apart. You basically need a stick of dynamite.
We had an old KB aluminum block that we were trying to use on the street and couldn't keep the oil and water separated. So we used The right Stuff on the sleeves. It was the only thing we tried that worked.
Master, again and still
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: RapidRobert] #2070023
05/09/16 12:36 PM
05/09/16 12:36 PM
S.E. Minnesota
gtsdude Offline
gtsdude  Offline
S.E. Minnesota
That is good stuff, the gray International stuff is very good also, 7.3 power strokes have no oil pan gasket, just the RTV, a chisel and hammer is needed to get the oil pan off.
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: DaveRS23] #2070025
05/09/16 12:37 PM
05/09/16 12:37 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
I agree. It is nothing more then Windshield urethane. Works good, but I would use it as a last resort, no other option.
69 GTX 68 Road Runner
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: JERICOGTX] #2070207
05/09/16 05:42 PM
05/09/16 05:42 PM
(1) agreed it is the cats ass to get back off & once you deal with that once you'll forever be judicious on how (where) you use it in the future & that stat housing just would not seal (I think the flanges on em should be made wider). (2) interesting that is what it is. way back I did a windshield & bought the hardening stuff (& it was like that (TRS) now that I think on it) & years later I did another one & the same auto body supply store only sold the non hardening stuff so I went with that
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: RapidRobert] #2070362
05/09/16 09:57 PM
05/09/16 09:57 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Good Stuff that Right Stuff, I hard an oil leak under the front of my Indy intake and didn`t want to pull the manifold off, a little Right Stuff did the trick No more leak. I usually use the black Right Stuff when I purchased it for they manifold I didn`t realize I had bought the Gray Right Stuff but it worked out great as you can hardly see it there. The oil pan on my 363 always seemed to leak , a little Right Stuff fixed that also
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: RapidRobert] #2070435
05/09/16 11:34 PM
05/09/16 11:34 PM
Alberta
Wookie316 Offline
Wookie316  Offline
Alberta
I love "The Right Stuff" until the engine has to come apart. But I'd rather be leak free and have to beat things apart later opposed to leaks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: RapidRobert] #2070459
05/10/16 12:13 AM
05/10/16 12:13 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
Xylene(available at paint stores)will break the bond and help with getting off that thin film that sometimes remains. It is a strong and slow evaporation solvent. Wear good gloves.
Re: Thumbs up for "the right stuff" Permatex gasket maker [Re: A/MP] #2070510
05/10/16 01:26 AM
05/10/16 01:26 AM
A/MP Noted!
