Thumbs up for "the right stuff" Permatex gasket maker
#2069878
05/09/16 02:51 AM
05/09/16 02:51 AM
RapidRobert
I gotta give a shout out for this stuff. it sealed a temp sender into the intake that Indian head would not seal (tho it is pipe threads and in all fairness pipe dope may have sealed it but I was out) but the sender into the adapter ain't NPT and the stat housing that would not seal after multiple attempts (including drawfiling it flat (& a new one from NAPA) & on that it even took TRS gasket maker PLUS the gasket! On a side note the NAPA housing has a straight flange/no barb on the end like the OE Mopar one, I highly suggest filing a wide groove in it (I got a hot antifreeze bath in the middle of this ordeal!). All good (in the hood) now
Re: Thumbs up for "the right stuff" Permatex gasket maker
[Re: RapidRobert]
#2069967
05/09/16 11:04 AM
05/09/16 11:04 AM
Posts: 12,103 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Yep, that stuff is great! Until you want to take it apart. You basically need a stick of dynamite. We had an old KB aluminum block that we were trying to use on the street and couldn't keep the oil and water separated. So we used The right Stuff on the sleeves. It was the only thing we tried that worked.
Master, again and still
[Re: DaveRS23]
#2070025
05/09/16 12:37 PM
05/09/16 12:37 PM
Posts: 10,027 MN
JERICOGTX
MN
Yep, that stuff is great! Until you want to take it apart. You basically need a stick of dynamite. I agree. It is nothing more then Windshield urethane. Works good, but I would use it as a last resort, no other option.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2070207
05/09/16 05:42 PM
05/09/16 05:42 PM
RapidRobert
Yep, that stuff is great! Until you want to take it apart. You basically need a stick of dynamite. I agree. It is nothing more then Windshield urethane. Works good, but I would use it as a last resort, no other option. (1) agreed it is the cats ass to get back off & once you deal with that once you'll forever be judicious on how (where) you use it in the future & that stat housing just would not seal (I think the flanges on em should be made wider). (2) interesting that is what it is. way back I did a windshield & bought the hardening stuff (& it was like that (TRS) now that I think on it) & years later I did another one & the same auto body supply store only sold the non hardening stuff so I went with that
[Re: RapidRobert]
#2070362
05/09/16 09:57 PM
05/09/16 09:57 PM
Posts: 4,984 new jersey usa
11secdart
new jersey usa
Good Stuff that Right Stuff, I hard an oil leak under the front of my Indy intake and didn`t want to pull the manifold off, a little Right Stuff did the trick No more leak. I usually use the black Right Stuff when I purchased it for they manifold I didn`t realize I had bought the Gray Right Stuff but it worked out great as you can hardly see it there. The oil pan on my 363 always seemed to leak , a little Right Stuff fixed that also
[Re: RapidRobert]
#2070435
05/09/16 11:34 PM
05/09/16 11:34 PM
Posts: 326 Alberta
Wookie316
Alberta
I love "The Right Stuff" until the engine has to come apart. But I'd rather be leak free and have to beat things apart later opposed to leaks.
1971 Plum Crazy Super Bee. 572 World Aluminum block with a Cope 727 & Dana 4.10 out back. 9.88 @ 138 with a 1.35 60 NA. Dialed back to 10.0’s. 4000 lbs with me in it.
