67 cuda blower motor ground wire?
#2066663
05/03/16 07:37 PM
05/03/16 07:37 PM
Posts: 5,668 South Dakota
hotairballoonpilot
South Dakota
Trying to reassemble a 67 cuda that we did not take apart. There is a wire for the blower motor that has 2 eyelet holes in it for a ground. They are separate on the wire from one another. Dash is all in the car but have that wire that I am trying to locate where it goes. Any clues?
corey
Contact Me about AMD Prices
Re: 67 cuda blower motor ground wire?
[Re: hotairballoonpilot]
#2067001
05/04/16 09:10 AM
05/04/16 09:10 AM
RapidRobert
the wiring diagrams at www.mymopar.com MAY have that detail. What I would do is ohm em & see if checking basic continuity will help you locate where the other end of em goes to. or take it off & on your bench with a 12V battery see what you can figure out (always ohm everything to avoid any dead shorts)
[Re: RapidRobert]
#2067028
05/04/16 10:26 AM
05/04/16 10:26 AM
Posts: 43,572 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
One for sure goes to the clamp for the tubes of the heater core inside the car where there is a single screw that goes through the clamp, can't remember off hand where the other one goes...
JB Rhinehart, Realist
A-Body's RULE!
[Re: Rhinodart]
#2067772
05/05/16 03:08 PM
05/05/16 03:08 PM
Posts: 2,580 CT - just outside Hartford
Crazy73
One for sure goes to the clamp for the tubes of the heater core inside the car where there is a single screw that goes through the clamp, can't remember off hand where the other one goes... IIRC the other goes to a ground on the inside of the dash. My heater box ('68 barracuda) is out of the car right now but the ground wiring is still connected at the heater core.
Pete -1968 Barracuda 4spd 383-6pk
