67 cuda blower motor ground wire? #2066663
05/03/16 07:37 PM
05/03/16 07:37 PM
South Dakota
hotairballoonpilot Offline OP
South Dakota
Trying to reassemble a 67 cuda that we did not take apart. There is a wire for the blower motor that has 2 eyelet holes in it for a ground. They are separate on the wire from one another. Dash is all in the car but have that wire that I am trying to locate where it goes. Any clues?
corey
Contact Me about AMD Prices
Re: 67 cuda blower motor ground wire? [Re: hotairballoonpilot] #2067001
05/04/16 09:10 AM
05/04/16 09:10 AM
the wiring diagrams at www.mymopar.com MAY have that detail. What I would do is ohm em & see if checking basic continuity will help you locate where the other end of em goes to. or take it off & on your bench with a 12V battery see what you can figure out (always ohm everything to avoid any dead shorts)
Re: 67 cuda blower motor ground wire? [Re: RapidRobert] #2067028
05/04/16 10:26 AM
05/04/16 10:26 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
One for sure goes to the clamp for the tubes of the heater core inside the car where there is a single screw that goes through the clamp, can't remember off hand where the other one goes... work
JB Rhinehart, Realist
A-Body's RULE!
Re: 67 cuda blower motor ground wire? [Re: hotairballoonpilot] #2067765
05/05/16 02:44 PM
05/05/16 02:44 PM
South Dakota
South Dakota
thanks guys!!!
Re: 67 cuda blower motor ground wire? [Re: Rhinodart] #2067772
05/05/16 03:08 PM
05/05/16 03:08 PM
CT - just outside Hartford
Crazy73 Offline
Crazy73  Offline
IIRC the other goes to a ground on the inside of the dash. My heater box ('68 barracuda) is out of the car right now but the ground wiring is still connected at the heater core.
Pete
-1968 Barracuda 4spd 383-6pk
Re: 67 cuda blower motor ground wire? [Re: hotairballoonpilot] #2067773
05/05/16 03:11 PM
05/05/16 03:11 PM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
On my 68 Dart, the other wire goes to the body behind the kick panel.
