Viking shocks...
#2065547
05/01/16 10:31 PM
05/01/16 10:31 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
I am about to buy some double adjustable front shocks and they do not make them for my D50. Do I just measure the extension and compression of the stock shocks and buy a set close to the same measurement. Thanks.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Viking shocks...
[Re: D-50]
#2065592
05/01/16 11:27 PM
05/01/16 11:27 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Yes just don't go shorter, match the mounting style.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: D-50]
#2065614
05/01/16 11:58 PM
05/01/16 11:58 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
I would take a ride height measurement and a fully extended measurement give them a call they're very helpful.. and no your current length
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: D-50]
#2065664
05/02/16 01:14 AM
05/02/16 01:14 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I would love to hear how they work out. I want to get them for my 68 Charger. The world block is about 50 lbs heavier than a stock one and I have the 1.15 torsion bars from Bergman. I think that the shocks would make a difference compared to an off the shelf shock. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: astjp2]
#2065736
05/02/16 08:46 AM
05/02/16 08:46 AM
Posts: 5,895 Florida
Locomotion
I would love to hear how they work out. I want to get them for my 68 Charger. The world block is about 50 lbs heavier than a stock one and I have the 1.15 torsion bars from Bergman. I think that the shocks would make a difference compared to an off the shelf shock. Tim If I remember correctly, Viking is owned by the original owners of QA1. It might be noted on the Viking website. Nice stuff. Myron
[Re: Locomotion]
#2065766
05/02/16 10:31 AM
05/02/16 10:31 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
I would love to hear how they work out. I want to get them for my 68 Charger. The world block is about 50 lbs heavier than a stock one and I have the 1.15 torsion bars from Bergman. I think that the shocks would make a difference compared to an off the shelf shock. Tim If I remember correctly, Viking is owned by the original owners of QA1. It might be noted on the Viking website. Nice stuff. Myron ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I put a set of them on my car and it made a huge difference. Allowed me to use all this extra power from the nitrous. Before it was just going up in smoke no matter what I did. Can ran consistent mid 9s on motor, but wouldn't do anything on the nitrous really until I changed shocks.
[Re: an8sec70cuda]
#2065931
05/02/16 02:39 PM
05/02/16 02:39 PM
Posts: 447 NJ
JCCuda
NJ
Myron [/quote] ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) I put a set of them on my car and it made a huge difference. Allowed me to use all this extra power from the nitrous. Before it was just going up in smoke no matter what I did. Can ran consistent mid 9s on motor, but wouldn't do anything on the nitrous really until I changed shocks. [/quote] Did you go with the Viking Warrior series or the Crusader Series? What shocks did you have on the car before you made the change? My car is a 10.00 footbrake bracket car that has a stock loose non adjustable on the front right now and I'm not sure if the Warrior is sufficient or if I need to step up to the Crusader. Any adjustable I put on it should be an improvement but I hope to only pay once. The rear shocks on my car are Afco double adjustable's with a ladder bar.
[Re: D-50]
#2066010
05/02/16 04:54 PM
05/02/16 04:54 PM
an8sec70cuda
I had tried a few different shocks up front...CE 3 ways, Calvery 90/10s, and some home modified Lakewood 90/10 shocks. The Lakewoods worked the best when the car was naturally aspirated. I had the Rancho 9 ways on the back.
The Viking front shocks are just their standard double adjustable. From what they told me when I bought them, they don't offer a Crusader option for front shocks. The Viking rears I got the Crusader option, which is what they recommended for high powered applications.
[Re: an8sec70cuda]
#2066234
05/02/16 11:40 PM
05/02/16 11:40 PM
astjp2
Utah and Alaska
What is the crusader option? I had tried a few different shocks up front...CE 3 ways, Calvery 90/10s, and some home modified Lakewood 90/10 shocks. The Lakewoods worked the best when the car was naturally aspirated. I had the Rancho 9 ways on the back.
[Re: D-50]
#2066408
05/03/16 10:28 AM
05/03/16 10:28 AM
an8sec70cuda
astjp2...stiffer valving for high powered applications.
