Viking shocks... #2065547
05/01/16 10:31 PM
05/01/16 10:31 PM
North, Alabama
D-50 Offline OP
D-50  Offline OP
North, Alabama
I am about to buy some double adjustable front shocks and they do not make them for my D50. Do I just measure the extension and compression of the stock shocks and buy a set close to the same measurement. Thanks.....
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Viking shocks... [Re: D-50] #2065592
05/01/16 11:27 PM
05/01/16 11:27 PM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes just don't go shorter, match the mounting style.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Viking shocks... [Re: 1967dartgt] #2065613
05/01/16 11:54 PM
05/01/16 11:54 PM
Locomotion Offline
Locomotion  Offline
They can also change the ends to accommodate your mounting needs if the correct length is found, but for a different application.
Re: Viking shocks... [Re: D-50] #2065614
05/01/16 11:58 PM
05/01/16 11:58 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I would take a ride height measurement and a fully extended measurement give them a call they're very helpful.. and no your current length
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Viking shocks... [Re: D-50] #2065664
05/02/16 01:14 AM
05/02/16 01:14 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
I would love to hear how they work out. I want to get them for my 68 Charger. The world block is about 50 lbs heavier than a stock one and I have the 1.15 torsion bars from Bergman. I think that the shocks would make a difference compared to an off the shelf shock. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Viking shocks... [Re: astjp2] #2065736
05/02/16 08:46 AM
05/02/16 08:46 AM
Locomotion Offline
Locomotion  Offline
If I remember correctly, Viking is owned by the original owners of QA1. It might be noted on the Viking website. Nice stuff.
Myron
Re: Viking shocks... [Re: Locomotion] #2065766
05/02/16 10:31 AM
05/02/16 10:31 AM
an8sec70cuda Offline
Myron
iagree I put a set of them on my car and it made a huge difference. Allowed me to use all this extra power from the nitrous. Before it was just going up in smoke no matter what I did. Can ran consistent mid 9s on motor, but wouldn't do anything on the nitrous really until I changed shocks.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Viking shocks... [Re: an8sec70cuda] #2065931
05/02/16 02:39 PM
05/02/16 02:39 PM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Myron [/quote]
iagree I put a set of them on my car and it made a huge difference. Allowed me to use all this extra power from the nitrous. Before it was just going up in smoke no matter what I did. Can ran consistent mid 9s on motor, but wouldn't do anything on the nitrous really until I changed shocks. [/quote]
Did you go with the Viking Warrior series or the Crusader Series? What shocks did you have on the car before you made the change? My car is a 10.00 footbrake bracket car that has a stock loose non adjustable on the front right now and I'm not sure if the Warrior is sufficient or if I need to step up to the Crusader. Any adjustable I put on it should be an improvement but I hope to only pay once. The rear shocks on my car are Afco double adjustable's with a ladder bar.
Re: Viking shocks... [Re: D-50] #2066010
05/02/16 04:54 PM
05/02/16 04:54 PM
I had tried a few different shocks up front...CE 3 ways, Calvery 90/10s, and some home modified Lakewood 90/10 shocks. The Lakewoods worked the best when the car was naturally aspirated.
I had the Rancho 9 ways on the back.
The Viking front shocks are just their standard double adjustable. From what they told me when I bought them, they don't offer a Crusader option for front shocks. The Viking rears I got the Crusader option, which is what they recommended for high powered applications.
CHIP
Re: Viking shocks... [Re: an8sec70cuda] #2066234
05/02/16 11:40 PM
05/02/16 11:40 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
What is the crusader option?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Viking shocks... [Re: astjp2] #2066255
05/03/16 12:13 AM
05/03/16 12:13 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
They offer custom valving for various applications, last time I checked it was $75 usd each. Here is their page on the specifics. They prototyped a very trick aftermarket active shock system @ SEMA 2014, but they don't have any more info on it. shruggy
Re: Viking shocks... [Re: D-50] #2066408
05/03/16 10:28 AM
05/03/16 10:28 AM
astjp2...stiffer valving for high powered applications.
CHIP
