header gasket preferance on a 440 with headers ??? #2064711
04/30/16 02:25 PM
04/30/16 02:25 PM
colorado
cocamcuda Offline OP
colorado
what brand of header gaskets hold up well w/o blowing out, on a 440, with edelbrock rpm heads and hooker headers.??? I am planning on using the new mr.gasket header bolts ,that don't back out.thanks jim
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064744
04/30/16 03:08 PM
04/30/16 03:08 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
1. Check if your headers' flanges are flat. If you can detect any warping, no gasket it going to seal properly. Look especially between the two center ports which have to rely on only two bolts to clamp down the siamesed exhaust ports.
2. If the headers are OK, I've had good results w/ Mr. Gasket UltraSeal and (even though they look flimsy), the Indy-brand header gaskets. What TTI sells also looks decent, but I haven't tried those yet to know for sure.
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064800
04/30/16 04:41 PM
04/30/16 04:41 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I would suggest that U use studs in place of bolts...
Much easier to replace an exhaust gasket, plus no coolant leakage as well..
Regarding gasket brand, we like to use the Fel-Pro..
Just my $0.02... wink
Re: header gasket preferance on a 440 with headers ??? [Re: BradH] #2064807
04/30/16 04:55 PM
04/30/16 04:55 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Using Indy header gaskets with a thin coat of "Ultra Copper" on both sides...no leaks yet.
luck
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064818
04/30/16 05:07 PM
04/30/16 05:07 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I have had good luck with Percy's carbon fiber and Mr. Gasket ultra seals on my ride.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064860
04/30/16 06:28 PM
04/30/16 06:28 PM
jersey
Spaceman Spiff Offline
jersey
REMFLEX.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: header gasket preferance on a 440 with headers ??? [Re: Sinitro] #2064866
04/30/16 06:38 PM
04/30/16 06:38 PM
BradH Offline
BradH  Offline
x2 on using studs, if you can install the headers w/ them. Some headers require a lot of "gymnastics" to get the nut over the end of certain studs depending on how the tubes are routed, and it's simply easier to get a bolt started.
Re: Fel-Pro header gaskets... need to check the size of their openings vs. the exhaust port & header flange openings. I've found they're simply too small for larger ports and headers.
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064885
04/30/16 07:14 PM
04/30/16 07:14 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
X2 on remflex.
My headers suck and remflex seals them
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064889
04/30/16 07:23 PM
04/30/16 07:23 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
One thing on the studs is sometimes with certain headers studs cant be used as they dont always fit good. I know on my TTI and CPPA headers on our cars you cant use studs on some bolts as they just wont fit. Ron
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064902
04/30/16 08:00 PM
04/30/16 08:00 PM
Shannonville, Ont
Blown 68 R/T Offline
Shannonville, Ont
REMFLEX are the best!
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064933
04/30/16 09:06 PM
04/30/16 09:06 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Ultra-Seal's under flanges that were surfaced has kept my Hooker's happy for a lot of years...
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2064998
04/30/16 10:56 PM
04/30/16 10:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use nothing but Mr Gasket ultra seals.Even the valve covers are the ones.Ive had headers on and off and reused them.My kid did have to replace one on his 413 after 6 or 7 years and being off once.Not bad for like 20 bucks.Rocky
Chrysler Firepower
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065005
04/30/16 11:09 PM
04/30/16 11:09 PM
Central NC
gch Offline
gch  Offline
Central NC
I have used nothing but the blue fel pro ones for years.Even re-use them several times off and on.Flat flanges is the key no matter what you use.
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065034
04/30/16 11:53 PM
04/30/16 11:53 PM
PA
Scully Offline
Scully  Offline
PA
Just a short story here. In 93 I bought my Davis step headers for my Max and went to the local track for some time runs with MR Gasket gaskets, by the time I unloaded the car the gaskets were blown so I made a few passes and left. The following week I went out with the Fel-Pro 1414 and opened them to the max exhaust size with my die grinder,it was a perfect seal. 2016, 23 years later the same gaskets are on the car, 4 different sets of heads and the headers have been removed and reinstalled many times, the gaskets look like the day I first put them on.
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065038
05/01/16 12:06 AM
05/01/16 12:06 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Percy Carbons.
69 GTX 68 Road Runner
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065231
05/01/16 01:11 PM
05/01/16 01:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been using the Fel-pro permatorque for years w/just a smear of grease and they last years and don`t leak...........
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065241
05/01/16 01:24 PM
05/01/16 01:24 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Never tried Remflex. After having hood luck with Ultraseals I stayed with them shruggy
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: header gasket preferance on a 440 with headers ??? [Re: Spaceman Spiff] #2065376
05/01/16 05:45 PM
05/01/16 05:45 PM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Originally Posted By Spaceman Spiff
REMFLEX.
Putting a set of these on my 86 Grand Wagoneer today. They are interesting but the Jeep/AMC guys I know swear by them.
eBay-cdwmotorsports
Re: header gasket preferance on a 440 with headers ??? [Re: cocamcuda] #2065384
05/01/16 06:00 PM
05/01/16 06:00 PM
Washington
skrews Offline
skrews  Offline
Washington
Perceys carbon X or remflex. Both will seal on just about anything.
Re: header gasket preferance on a 440 with headers ??? [Re: skrews] #2065604
05/01/16 11:37 PM
05/01/16 11:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I wish I knew who made the ones that came with my Doug's headers because they have been on there for about 7 years with not a peep. It helps that they have perfect thick flanges and I even used the bolts and lock washers they came with shruggy I pulled them tight after the first heat cycle and haven't touched them since up
Gus beer
64 Plymouth Savoy
Dana 60
