Re: header gasket preferance on a 440 with headers ???
[Re: cocamcuda]
#2064800
04/30/16 04:41 PM
04/30/16 04:41 PM
Posts: 5,445 So Cal
Sinitro
So Cal
I would suggest that U use studs in place of bolts... Much easier to replace an exhaust gasket, plus no coolant leakage as well.. Regarding gasket brand, we like to use the Fel-Pro.. Just my $0.02...
[Re: cocamcuda]
#2064818
04/30/16 05:07 PM
04/30/16 05:07 PM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
I have had good luck with Percy's carbon fiber and Mr. Gasket ultra seals on my ride.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: Sinitro]
#2064866
04/30/16 06:38 PM
04/30/16 06:38 PM
BradH
I would suggest that U use studs in place of bolts... Much easier to replace an exhaust gasket, plus no coolant leakage as well.. Regarding gasket brand, we like to use the Fel-Pro.. Just my $0.02... x2 on using studs, if you can install the headers w/ them. Some headers require a lot of "gymnastics" to get the nut over the end of certain studs depending on how the tubes are routed, and it's simply easier to get a bolt started. Re: Fel-Pro header gaskets... need to check the size of their openings vs. the exhaust port & header flange openings. I've found they're simply too small for larger ports and headers.
[Re: cocamcuda]
#2064998
04/30/16 10:56 PM
04/30/16 10:56 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
We use nothing but Mr Gasket ultra seals.Even the valve covers are the ones.Ive had headers on and off and reused them.My kid did have to replace one on his 413 after 6 or 7 years and being off once.Not bad for like 20 bucks.Rocky
Chrysler Firepower
[Re: cocamcuda]
#2065231
05/01/16 01:11 PM
05/01/16 01:11 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
Been using the Fel-pro permatorque for years w/just a smear of grease and they last years and don`t leak...........
[Re: Spaceman Spiff]
#2065376
05/01/16 05:45 PM
05/01/16 05:45 PM
Posts: 1,457 Martinsville, IN
cdwmotorsports
Martinsville, IN
Putting a set of these on my 86 Grand Wagoneer today. They are interesting but the Jeep/AMC guys I know swear by them.
eBay-cdwmotorsports
[Re: skrews]
#2065604
05/01/16 11:37 PM
05/01/16 11:37 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I wish I knew who made the ones that came with my Doug's headers because they have been on there for about 7 years with not a peep. It helps that they have perfect thick flanges and I even used the bolts and lock washers they came with I pulled them tight after the first heat cycle and haven't touched them since Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
