cleaning deposits off pistons while in block, while in car ? #2064704
04/30/16 02:16 PM
04/30/16 02:16 PM
colorado
cocamcuda Offline OP
colorado
I have pulled the 440 source heads off my 440,the top of the pistons have fouling/deposits on them and would like to clean them off before installing new edelbrock rpm heads. any thoughts, scotch brite pad.???thanks jim
Re: cleaning deposits off pistons while in block, while in car ? [Re: cocamcuda] #2064722
04/30/16 02:36 PM
04/30/16 02:36 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
i always use wd40
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
Re: cleaning deposits off pistons while in block, while in car ? [Re: oldiron] #2064746
04/30/16 03:08 PM
04/30/16 03:08 PM
be sure to put some grease around the edges to contain the mess and a shop vac handy and you can duct tape a smaller hose to the nozzle so you can easily get in there. As said a scotch pad is fine. I would spray em with something & let it set overnight & with it all wet it makes it easier to contain the dust/debris that would be kicked up if doing em dry
Re: cleaning deposits off pistons while in block, while in car ? [Re: cocamcuda] #2064788
04/30/16 04:17 PM
04/30/16 04:17 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I did a TON of head gaskets at the dealer. Bring the piston to TDC. Clean them off with scotch brite, scraper ETC. Blow out around the top edge, roll the crank a little, wipe the bore, blow it out, roll, wipe. Follow with the others. No big deal.
Doug
Re: cleaning deposits off pistons while in block, while in car ? [Re: cocamcuda] #2064857
04/30/16 06:18 PM
04/30/16 06:18 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
I just did this with my 360 motor...I brought the pistons to TDC, installed a new blade in my gasket remover knife, worked the tops of the pistons while my shop-vac sucked up all the grime...worked out very well.
Re: cleaning deposits off pistons while in block, while in car ? [Re: Diplomat360] #2064877
04/30/16 06:59 PM
04/30/16 06:59 PM
I use a sharp single edge razor blade in my scraper to get the heavy stuff off before using anything else up scope
Re: cleaning deposits off pistons while in block, while in car ? [Re: cocamcuda] #2065159
05/01/16 10:47 AM
05/01/16 10:47 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Just as a future thought. Before ever taking it apart. Get it hot and mist water down it's throat for a while. Sounds crazy I know, but it'll steam clean them. An old water injection kit works great if you have one.
Re: cleaning deposits off pistons while in block, while in car ? [Re: dthemi] #2065181
05/01/16 11:46 AM
05/01/16 11:46 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
I don't normally clean the tops of my pistons.
But when I do, I make sure to run a shop rag through the top end before disassembly......
laugh2
Re: cleaning deposits off pistons while in block, while in car ? [Re: roadhazard] #2065189
05/01/16 11:53 AM
05/01/16 11:53 AM
Akron, Ohio U.S.A.
roadhazard Offline
roadhazard  Offline
Akron, Ohio U.S.A.
...... after the heavy deposits are removed smile
I use a single blade razor scraper to clean the rest with each piston @ TDC. Use compressed air to blow what may have gotten between the piston and cylinder wall then wipe with a rag and lacquer thinner.
Rotate multiple times and wipe each cylinder until they are spotless clean again. Oil the cylinder walls and reassemble.
Re: cleaning deposits off pistons while in block, while in car ? [Re: cocamcuda] #2065360
05/01/16 05:04 PM
05/01/16 05:04 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I don't like using scotch-brite on any internal parts that aren't going to be able to be thoroughly washed afterwards. Razor blade used carefully, vacuum, lacquer thinner or 2+2 on a towel, compressed air, turn it over by hand several times using WD40 on a towel to wipe the cylinder walls down. But then, I am anal.
Re: cleaning deposits off pistons while in block, while in car ? [Re: roadhazard] #2065362
05/01/16 05:06 PM
05/01/16 05:06 PM
Don't forget to oil the cylinder walls before startin it up also up twocents
Re: cleaning deposits off pistons while in block, while in car ? [Re: dthemi] #2065369
05/01/16 05:25 PM
05/01/16 05:25 PM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
I thought I was the only one who did that??? Yes, it works great.
OP: Why the change from 440 source to Eddy heads?
