Re: cleaning deposits off pistons while in block, while in car ?
[Re: oldiron]
#2064746
04/30/16 03:08 PM
04/30/16 03:08 PM
RapidRobert
be sure to put some grease around the edges to contain the mess and a shop vac handy and you can duct tape a smaller hose to the nozzle so you can easily get in there. As said a scotch pad is fine. I would spray em with something & let it set overnight & with it all wet it makes it easier to contain the dust/debris that would be kicked up if doing em dry
[Re: cocamcuda]
#2064788
04/30/16 04:17 PM
04/30/16 04:17 PM
Posts: 9,847 MI, usa
dvw
MI, usa
I did a TON of head gaskets at the dealer. Bring the piston to TDC. Clean them off with scotch brite, scraper ETC. Blow out around the top edge, roll the crank a little, wipe the bore, blow it out, roll, wipe. Follow with the others. No big deal. Doug
[Re: roadhazard]
#2065189
05/01/16 11:53 AM
05/01/16 11:53 AM
Posts: 3,675 Akron, Ohio U.S.A.
roadhazard
Akron, Ohio U.S.A.
...... after the heavy deposits are removed I use a single blade razor scraper to clean the rest with each piston @ TDC. Use compressed air to blow what may have gotten between the piston and cylinder wall then wipe with a rag and lacquer thinner. Rotate multiple times and wipe each cylinder until they are spotless clean again. Oil the cylinder walls and reassemble.
[Re: cocamcuda]
#2065360
05/01/16 05:04 PM
05/01/16 05:04 PM
Posts: 11,600 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I don't like using scotch-brite on any internal parts that aren't going to be able to be thoroughly washed afterwards. Razor blade used carefully, vacuum, lacquer thinner or 2+2 on a towel, compressed air, turn it over by hand several times using WD40 on a towel to wipe the cylinder walls down. But then, I am anal.
[Re: dthemi]
#2065369
05/01/16 05:25 PM
05/01/16 05:25 PM
Posts: 3,245 Between a rock & a hard place
cudadoug
Just as a future thought. Before ever taking it apart. Get it hot and mist water down it's throat for a while. Sounds crazy I know, but it'll steam clean them. An old water injection kit works great if you have one. I thought I was the only one who did that??? Yes, it works great. OP: Why the change from 440 source to Eddy heads?
