Screen in lifter valley? #2057432
04/19/16 07:15 AM
04/19/16 07:15 AM
gregsdart Offline OP
I want to put some form of screen into the lifter valley, but don't want a lot of oil piling up. Can anyone show me pictures, and what materials you used to do this to an iron block?
Re: Screen in lifter valley? [Re: gregsdart] #2057434
04/19/16 07:52 AM
04/19/16 07:52 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
like this you mean?
Re: Screen in lifter valley? [Re: rebel] #2057435
04/19/16 07:56 AM
04/19/16 07:56 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i did it to this block as well.
Re: Screen in lifter valley? [Re: gregsdart] #2057437
04/19/16 08:41 AM
04/19/16 08:41 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Nice work, Rebel.
[image][/image]
Re: Screen in lifter valley? [Re: sgcuda] #2057474
04/19/16 10:44 AM
04/19/16 10:44 AM
an8sec70cuda Offline
I know it's hard to see, but this is the only pic I have of it. This is the screen setup I have in the 436" sb chevy.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Screen in lifter valley? [Re: rebel] #2057648
04/19/16 03:17 PM
04/19/16 03:17 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
That is so cool!!!
I can understand why you want to do this trick. I built a 460 Ford motor for a truck swap and one of the retainer rings that restricts the cup in a hydraulic lifter came out and ended up jammed in the oil pump gears. Fortunately the oil pump drive shaft broke and the engine stopped sick
I dodged a bullet there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Screen in lifter valley? [Re: gregsdart] #2057673
04/19/16 03:39 PM
04/19/16 03:39 PM
Nice work on those screens up I need to go smaller mesh to stop needle bearings from getting down to the oil pump ,gear drive or oil pump gear. Anybody run anything with smaller mesh? I figured that it might work to put a finer mesh over the screen in the oil pan, but that might not protect the gear drive?
Re: Screen in lifter valley? [Re: gregsdart] #2058061
04/20/16 12:13 AM
04/20/16 12:13 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I've been putting screen in the valley for years..
I use a 1/8 mesh that I buy at the hardware store..
its metal(sorta like large screen door screen).. I
cut it to fit and run it up the back wall on my small
blocks..JB Weld to glue it in place... its saved my butt
a couple of times when stuff broke.. rocker parts and push
rods and lash caps.. I'll see if I have pics but I doubt
it.. no one normally wants to see stuff like that
wave
Re: Screen in lifter valley? [Re: gregsdart] #2058079
04/20/16 12:36 AM
04/20/16 12:36 AM
OH
TheBlackCar Offline
TheBlackCar  Offline
OH
Moroso sells a kit for a BBC that works. Comes with screens and epoxy.
Good Luck
Re: Screen in lifter valley? [Re: gregsdart] #2058184
04/20/16 05:09 AM
04/20/16 05:09 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
You could easily replicate this design with a finer mesh. I had seen a rocker arm break, fall into the valley & jammed the cam, snapped it so a whole lot of valves took a hit. A lot of damage from a minor incident. You can mold the end of the mesh to make a nice clearence guard for the cam drive. Sorry no pics.
Re: Screen in lifter valley? [Re: gregsdart] #2058226
04/20/16 09:35 AM
04/20/16 09:35 AM
The needles from the bearings are only about .060, so I will see what is available for screen that size.
Re: Screen in lifter valley? [Re: gregsdart] #2058830
04/21/16 03:50 AM
04/21/16 03:50 AM
Wild West
M_D Offline
M_D  Offline
Wild West
Greg, here is where you can get some small mesh screen:
http://www.mcmaster.com/#stainless-steel-mesh/=122nkc6
I would be tempted to use the 30x30 mesh size found in the Strainer-Grade Type 304 Stainless Steel Wire Cloth listing.
Re: Screen in lifter valley? [Re: gregsdart] #2058855
04/21/16 09:15 AM
04/21/16 09:15 AM
Thanks M-D I just ordered the 30x30 strainer mesh. Makes the most sense, will stop anything big enough to shear off the oil pump drive or do major damage up
Re: Screen in lifter valley? [Re: gregsdart] #2058868
04/21/16 10:03 AM
04/21/16 10:03 AM
moparx Online content
moparx  Online Content
one question keeps reoccurring to me. how small can you go before drain back problems crop up ? could that some how be helped if there were more drain back [hole] area added to the valley ?
beer
Re: Screen in lifter valley? [Re: moparx] #2058905
04/21/16 11:40 AM
04/21/16 11:40 AM
oregon
greendart408 Offline
oregon
Make sure you attach it with screws. Epoxy won't work with your alky.........
Re: Screen in lifter valley? [Re: moparx] #2058907
04/21/16 11:43 AM
04/21/16 11:43 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Drain back won't be a problem as long as the oil is at operating temperature. Preheating the oil is best.
Re: Screen in lifter valley? [Re: gregsdart] #2058941
04/21/16 12:41 PM
04/21/16 12:41 PM
Thanks for the tip on screws Greendart. I may try and come up with something that will snap into place, we will see how creative I can get. I run my motor hot, so drain back during a run shouldn't be an issue, and I have an Acusump as well.
Re: Screen in lifter valley? [Re: gregsdart] #2058960
04/21/16 01:09 PM
04/21/16 01:09 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Gregsdart thanks for starting this thread i was planning on starting a similar thread last week but you beat me to the punch.
Ive been doing some thinking about this and i ordered some of the SS mesh as well, im going to incorporate both the larger mesh for a top layer and for support and use the tighter mesh under the heavier mesh so it will hold its shape. Then sandwich some kind of a mount like what rebel posted to hold everthing together.
Does drilling and tapping the block in this fashion weaking the cam tunnel?
Thanks all
Check out my build on Facebook Ttoad Hurley its updated regularly
Re: Screen in lifter valley? [Re: turbo toad] #2058965
04/21/16 01:14 PM
04/21/16 01:14 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks all
No the drilling and tapping doesnt hurt unless
it was a BIG bolt.. 3/16 or 1/4 is plenty big
enough to hold that stuff
wave
Re: Screen in lifter valley? [Re: gregsdart] #2058969
04/21/16 01:17 PM
04/21/16 01:17 PM
michigan
turbo toad Offline
turbo toad  Offline
michigan
Thank Pbody 1/4 20 should do the trick atleast thats what i was planning on using
Im planning on using some small tubing and some fender washers for my mount
