Screen in lifter valley?
#2057432
04/19/16 07:15 AM
04/19/16 07:15 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I want to put some form of screen into the lifter valley, but don't want a lot of oil piling up. Can anyone show me pictures, and what materials you used to do this to an iron block?
Re: Screen in lifter valley?
[Re: sgcuda]
#2057474
04/19/16 10:44 AM
04/19/16 10:44 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
I know it's hard to see, but this is the only pic I have of it. This is the screen setup I have in the 436" sb chevy.
[Re: rebel]
#2057648
04/19/16 03:17 PM
04/19/16 03:17 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
i did it to this block as well. That is so cool!!! I can understand why you want to do this trick. I built a 460 Ford motor for a truck swap and one of the retainer rings that restricts the cup in a hydraulic lifter came out and ended up jammed in the oil pump gears. Fortunately the oil pump drive shaft broke and the engine stopped I dodged a bullet there.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: gregsdart]
#2057673
04/19/16 03:39 PM
04/19/16 03:39 PM
gregsdart
Nice work on those screens I need to go smaller mesh to stop needle bearings from getting down to the oil pump ,gear drive or oil pump gear. Anybody run anything with smaller mesh? I figured that it might work to put a finer mesh over the screen in the oil pan, but that might not protect the gear drive?
[Re: gregsdart]
#2058061
04/20/16 12:13 AM
04/20/16 12:13 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I've been putting screen in the valley for years.. I use a 1/8 mesh that I buy at the hardware store.. its metal(sorta like large screen door screen).. I cut it to fit and run it up the back wall on my small blocks..JB Weld to glue it in place... its saved my butt a couple of times when stuff broke.. rocker parts and push rods and lash caps.. I'll see if I have pics but I doubt it.. no one normally wants to see stuff like that
[Re: gregsdart]
#2058184
04/20/16 05:09 AM
04/20/16 05:09 AM
Posts: 4,647 aotearoa
rebel
aotearoa
Nice work on those screens I need to go smaller mesh to stop needle bearings from getting down to the oil pump ,gear drive or oil pump gear. Anybody run anything with smaller mesh? I figured that it might work to put a finer mesh over the screen in the oil pan, but that might not protect the gear drive? You could easily replicate this design with a finer mesh. I had seen a rocker arm break, fall into the valley & jammed the cam, snapped it so a whole lot of valves took a hit. A lot of damage from a minor incident. You can mold the end of the mesh to make a nice clearence guard for the cam drive. Sorry no pics.
[Re: gregsdart]
#2058941
04/21/16 12:41 PM
04/21/16 12:41 PM
gregsdart
Thanks for the tip on screws Greendart. I may try and come up with something that will snap into place, we will see how creative I can get. I run my motor hot, so drain back during a run shouldn't be an issue, and I have an Acusump as well.
[Re: gregsdart]
#2058960
04/21/16 01:09 PM
04/21/16 01:09 PM
Posts: 368 michigan
turbo toad
michigan
Gregsdart thanks for starting this thread i was planning on starting a similar thread last week but you beat me to the punch. Ive been doing some thinking about this and i ordered some of the SS mesh as well, im going to incorporate both the larger mesh for a top layer and for support and use the tighter mesh under the heavier mesh so it will hold its shape. Then sandwich some kind of a mount like what rebel posted to hold everthing together. Does drilling and tapping the block in this fashion weaking the cam tunnel? Thanks all
Check out my build on Facebook Ttoad Hurley its updated regularly
[Re: turbo toad]
#2058965
04/21/16 01:14 PM
04/21/16 01:14 PM
MR_P_BODY
Gregsdart thanks for starting this thread i was planning on starting a similar thread last week but you beat me to the punch. Ive been doing some thinking about this and i ordered some of the SS mesh as well, im going to incorporate both the larger mesh for a top layer and for support and use the tighter mesh under the heavier mesh so it will hold its shape. Then sandwich some kind of a mount like what rebel posted to hold everthing together. Does drilling and tapping the block in this fashion weaking the cam tunnel? Thanks all No the drilling and tapping doesnt hurt unless it was a BIG bolt.. 3/16 or 1/4 is plenty big enough to hold that stuff
[Re: gregsdart]
#2058969
04/21/16 01:17 PM
04/21/16 01:17 PM
Posts: 368 michigan
turbo toad
michigan
Thank Pbody 1/4 20 should do the trick atleast thats what i was planning on using Im planning on using some small tubing and some fender washers for my mount
