PROBLEM SOLVED.............. #2057296
04/19/16 12:14 AM
04/19/16 12:14 AM
State of confusion
Thumperdart Offline OP
State of confusion
So after the collar and all of the dizzy post`s, mine is finally rock solid and was strictly from rotor slot slop. I already run a rubber/nylon home made collar and made a shim to go over the bottom of the slot from a piece of brass feeler gauge and shaped it to fit and siliconed it on to stay and it cant come out cos the collar covers it........Thankxxx for the shim idea............. beer
Re: PROBLEM SOLVED.............. [Re: Thumperdart] #2057314
04/19/16 12:27 AM
04/19/16 12:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm glad you got it squared away... let me know what
happens when you pull your dist after some time..
curious if the shim falls out... but being I weld I
will continue to do it as I always have
wave
Re: PROBLEM SOLVED.............. [Re: MR_P_BODY] #2057338
04/19/16 12:46 AM
04/19/16 12:46 AM
State of confusion
State of confusion
I had to use the hold down to wedge it in the gear slot so if/when it comes, out it will be 1-piece....... laugh2
Re: PROBLEM SOLVED.............. [Re: Thumperdart] #2057359
04/19/16 01:14 AM
04/19/16 01:14 AM
Socal
littleVAL Offline
littleVAL  Offline
Socal
Why don't you bring it by the house i can put a little weld and clean it up in the mill. If you bring the drive we can make it fit perfect and you won't risk a piece after metal getting somewhere bad.
Re: PROBLEM SOLVED.............. [Re: littleVAL] #2057368
04/19/16 01:17 AM
04/19/16 01:17 AM
State of confusion
State of confusion
That would be the SMART way Don but it can`t go anywhere cos it`s captive by the collar and this is just a temp. deal and experiment.......I may take you up on that if you can braze........
Re: PROBLEM SOLVED.............. [Re: Thumperdart] #2057423
04/19/16 04:42 AM
04/19/16 04:42 AM
robin hood country
deaks Offline
deaks  Offline
robin hood country
I took my distributor out put it on the end of an anvil, gave it a sharp rap with an hammer on both ends of the tang and it fitted snug after that.
Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200#
best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft
best 60ft 1.36
Re: PROBLEM SOLVED.............. [Re: deaks] #2057441
04/19/16 08:53 AM
04/19/16 08:53 AM
MD-USA
Dodgeguy101 Offline
Dodgeguy101  Offline
MD-USA
Mick
Ah yes, the ford approach.
Re: PROBLEM SOLVED.............. [Re: Dodgeguy101] #2057492
04/19/16 11:24 AM
04/19/16 11:24 AM
Benton, IL.
DaveRS23 Online rolleyes
Special needs idiot
DaveRS23  Online Rolleyes
Special needs idiot
Benton, IL.
Mick
Oops. I almost said that I take a similar approach (except with a chisel) to tighten the fit between the two. But after seeing the Ford comment, I am glad I didn't.
laugh2
Master, again and still
Re: PROBLEM SOLVED.............. [Re: Dodgeguy101] #2057514
04/19/16 12:11 PM
04/19/16 12:11 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Mick
I was shown this approach by a true Mopar or Die guy years ago and have used it myself.
Re: PROBLEM SOLVED.............. [Re: Thumperdart] #2057579
04/19/16 01:53 PM
04/19/16 01:53 PM
robin hood country
deaks Offline
deaks  Offline
robin hood country
You don't need to bash the hell out of it, just hold the distributor with the end of the shaft on the anvil and give it a light rap, flip it over do the other side and try it.
Oh and here's one of my Fords.
Mick
best 60ft 1.36
Re: PROBLEM SOLVED.............. [Re: deaks] #2057796
04/19/16 06:30 PM
04/19/16 06:30 PM
State of confusion
State of confusion
Mick
Nice car and love Fords second to Mopars......... thumbs
Re: PROBLEM SOLVED.............. [Re: Thumperdart] #2057811
04/19/16 06:53 PM
04/19/16 06:53 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
That's a sweet little Stang
