Re: PROBLEM SOLVED..............
[Re: Thumperdart]
#2057314
04/19/16 12:27 AM
04/19/16 12:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm glad you got it squared away... let me know what happens when you pull your dist after some time.. curious if the shim falls out... but being I weld I will continue to do it as I always have
[Re: littleVAL]
#2057368
04/19/16 01:17 AM
04/19/16 01:17 AM
Thumperdart
State of confusion
That would be the SMART way Don but it can`t go anywhere cos it`s captive by the collar and this is just a temp. deal and experiment.......I may take you up on that if you can braze........
[Re: Thumperdart]
#2057423
04/19/16 04:42 AM
04/19/16 04:42 AM
Posts: 3,210 robin hood country
deaks
robin hood country
I took my distributor out put it on the end of an anvil, gave it a sharp rap with an hammer on both ends of the tang and it fitted snug after that. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: deaks]
#2057441
04/19/16 08:53 AM
04/19/16 08:53 AM
Posts: 632 MD-USA
Dodgeguy101
MD-USA
I took my distributor out put it on the end of an anvil, gave it a sharp rap with an hammer on both ends of the tang and it fitted snug after that. Mick Ah yes, the ford approach.
[Re: Dodgeguy101]
#2057492
04/19/16 11:24 AM
04/19/16 11:24 AM
Posts: 12,236 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I took my distributor out put it on the end of an anvil, gave it a sharp rap with an hammer on both ends of the tang and it fitted snug after that. Mick Ah yes, the ford approach. Oops. I almost said that I take a similar approach (except with a chisel) to tighten the fit between the two. But after seeing the Ford comment, I am glad I didn't.
Master, again and still
[Re: Dodgeguy101]
#2057514
04/19/16 12:11 PM
04/19/16 12:11 PM
BradH
I took my distributor out put it on the end of an anvil, gave it a sharp rap with an hammer on both ends of the tang and it fitted snug after that. Mick Ah yes, the ford approach. I was shown this approach by a true Mopar or Die guy years ago and have used it myself.
[Re: Thumperdart]
#2057579
04/19/16 01:53 PM
04/19/16 01:53 PM
deaks
robin hood country
You don't need to bash the hell out of it, just hold the distributor with the end of the shaft on the anvil and give it a light rap, flip it over do the other side and try it. Oh and here's one of my Fords. Mick
[Re: deaks]
#2057796
04/19/16 06:30 PM
04/19/16 06:30 PM
Thumperdart
State of confusion
You don't need to bash the hell out of it, just hold the distributor with the end of the shaft on the anvil and give it a light rap, flip it over do the other side and try it. Oh and here's one of my Fords. Mick Nice car and love Fords second to Mopars.........
[Re: Thumperdart]
#2057811
04/19/16 06:53 PM
04/19/16 06:53 PM
Posts: 17,923 Akron, Ohio
ProSport
Akron, Ohio
That's a sweet little Stang
