'69 "Cuda" or "Formula S" grille finishes #2055747
04/16/16 09:16 PM
04/16/16 09:16 PM
Ontario, Canada
RealWing Offline OP
RealWing  Offline OP
Ontario, Canada
What is the correct black finish on both the egg crate section and the surround piece?? Gloss black, semi gloss black, satin black?????
Thx
1970 Superbird 440-6bbl, auto
1969 Barracuda 340-4bbl, FB Formula S auto
1969 Barracuda 6.1 L Hemi, 5 speed, Convertible
2022 Can Am Spyder RTL
Re: '69 "Cuda" or "Formula S" grille finishes [Re: RealWing] #2055800
04/16/16 11:02 PM
04/16/16 11:02 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Thx
Flat on the grill,painted, and the surrounds where not painted just black plastic out of the molds, on the shiny side
Standard surrounds where grey plastic painted silver
Re: '69 "Cuda" or "Formula S" grille finishes [Re: cudaman1969] #2055847
04/17/16 12:19 AM
04/17/16 12:19 AM
Ontario, Canada
RealWing Offline OP
RealWing  Offline OP
Ontario, Canada
Thx
Thanks!!!
Re: '69 "Cuda" or "Formula S" grille finishes [Re: RealWing] #2055888
04/17/16 01:01 AM
04/17/16 01:01 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
AFAIK the front or leading edge of the egg crate section is unpainted. The rest of it is flat black. This is based on the appearance of my one owner 1969 340-S.
I restored the egg crates by painting them from the rear with flat black and with tape masking off the front edges. Or you can paint first then sandpaper the paint off the front edge if you think the egg crate is stout enough to withstand sanding.
Re: '69 "Cuda" or "Formula S" grille finishes [Re: RealWing] #2056394
04/17/16 09:38 PM
04/17/16 09:38 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
That is correct regarding the mesh grill.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: '69 "Cuda" or "Formula S" grille finishes [Re: kentj340] #2057912
04/19/16 09:36 PM
04/19/16 09:36 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Yes, I did a second set like that, spray flat then sand front with a 2 inch block of wood and 1000 grit paper
Re: '69 "Cuda" or "Formula S" grille finishes [Re: RealWing] #2063823
04/29/16 04:53 AM
04/29/16 04:53 AM
OhiO
drgordi Offline
drgordi  Offline
OhiO
I have one molded grey surround that I am positive It was painted from the factory black on the inside. When I took off the aluminum trim there was black paint where you couldnt get it without having that trim off. If someone did they had the correct rivets to put it back on. This is my one and only experience with it.
Re: '69 "Cuda" or "Formula S" grille finishes [Re: RealWing] #2065039
05/01/16 12:06 AM
05/01/16 12:06 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Never say never but I have two sets of black and one gray. One of the black is cracked and its black inside. Gray is broken in numerous pieces and gray inside. After 47 years you will see anything.
