'69 "Cuda" or "Formula S" grille finishes
#2055747
04/16/16 09:16 PM
04/16/16 09:16 PM
Posts: 315 Ontario, Canada
RealWing
Ontario, Canada
What is the correct black finish on both the egg crate section and the surround piece?? Gloss black, semi gloss black, satin black????? Thx Jim
1970 Superbird 440-6bbl, auto 1969 Barracuda 340-4bbl, FB Formula S auto 1969 Barracuda 6.1 L Hemi, 5 speed, Convertible 2022 Can Am Spyder RTL
Re: '69 "Cuda" or "Formula S" grille finishes
[Re: RealWing]
#2055800
04/16/16 11:02 PM
04/16/16 11:02 PM
Posts: 8,275 fredericksburg,va
cudaman1969
fredericksburg,va
What is the correct black finish on both the egg crate section and the surround piece?? Gloss black, semi gloss black, satin black????? Thx Jim Flat on the grill,painted, and the surrounds where not painted just black plastic out of the molds, on the shiny side Standard surrounds where grey plastic painted silver
[Re: cudaman1969]
#2055847
04/17/16 12:19 AM
04/17/16 12:19 AM
RealWing
Ontario, Canada
What is the correct black finish on both the egg crate section and the surround piece?? Gloss black, semi gloss black, satin black????? Thx Jim Flat on the grill,painted, and the surrounds where not painted just black plastic out of the molds, on the shiny side Standard surrounds where grey plastic painted silver Thanks!!!
[Re: RealWing]
#2055888
04/17/16 01:01 AM
04/17/16 01:01 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
AFAIK the front or leading edge of the egg crate section is unpainted. The rest of it is flat black. This is based on the appearance of my one owner 1969 340-S.
I restored the egg crates by painting them from the rear with flat black and with tape masking off the front edges. Or you can paint first then sandpaper the paint off the front edge if you think the egg crate is stout enough to withstand sanding.
[Re: RealWing]
#2056394
04/17/16 09:38 PM
04/17/16 09:38 PM
Posts: 16,484 On the run…
BloFish
On the run…
That is correct regarding the mesh grill.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: kentj340]
#2057912
04/19/16 09:36 PM
04/19/16 09:36 PM
cudaman1969
fredericksburg,va
I restored the egg crates by painting them from the rear with flat black and with tape masking off the front edges. Or you can paint first then sandpaper the paint off the front edge if you think the egg crate is stout enough to withstand sanding. Yes, I did a second set like that, spray flat then sand front with a 2 inch block of wood and 1000 grit paper
