Hurst Quarter Stick function question #2053688
04/13/16 03:18 PM
04/13/16 03:18 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
Hey Guy's. back to working on a project after a long time away due to health issues. have a question regarding a Hurst Quarter Stick auto shifter I purchased like new, barely used. it's in a Duster, 727 standard V.B. when I pull stick all the way to rear, i can bump forward to 2nd, but have to pull lever to go to 3rd. should I be able to bump to 3rd without pulling lever ? unhooked cable at shifter & still the same(hoping to rule out adjustment at trans being the problem).is this the correct way this thing should function, or is something not correct ? Thanks, Tom
Re: Hurst Quarter Stick function question [Re: Tom Fox] #2053692
04/13/16 03:20 PM
04/13/16 03:20 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
That's how it's supposed to work.
Re: Hurst Quarter Stick function question [Re: Tom Fox] #2053704
04/13/16 03:34 PM
04/13/16 03:34 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
That so you can't miss a shift
Re: Hurst Quarter Stick function question [Re: GY3] #2053720
04/13/16 03:58 PM
04/13/16 03:58 PM
an8sec70cuda Offline
iagree Yep, that's how it works for a standard or forward pattern valvebody.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hurst Quarter Stick function question [Re: an8sec70cuda] #2053736
04/13/16 04:36 PM
04/13/16 04:36 PM
florida/ Georgia
Tom Fox Offline OP
Tom Fox  Offline OP
florida/ Georgia
well Darn, don't know why I thought I would be able to go though all gears by slapping stick forward. Thanks Guy's.
Re: Hurst Quarter Stick function question [Re: Tom Fox] #2053765
04/13/16 05:25 PM
04/13/16 05:25 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
When we were running the 3 speed, we had one set up to make the critical 1-2 shift with air and the 2-3 shift by hand. Worked great, especially with the 2.74. Uncomplicated, easy, consistent.
Re: Hurst Quarter Stick function question [Re: Tom Fox] #2053835
04/13/16 07:51 PM
04/13/16 07:51 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thats the reason I went with the Pro Ratchet..
just keep hitting the handle... my Quick Silver
I have to lift the handle from drive to get neutral
or reverse and park.. it has its pluses and minuses
wave
Re: Hurst Quarter Stick function question [Re: MR_P_BODY] #2053887
04/13/16 09:44 PM
04/13/16 09:44 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I drive mine a lot on the street so I'm used to it.
Never an issue.
