Bigblock Blower motor in an A-body-WHICH RADIATOR?? #2052347
04/11/16 11:47 PM
04/11/16 11:47 PM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Ok-I finally have the blower motor in my 68 dart and I need to know what radiator will fit and cool a 650-700 Horse 440. HELP! I would post a picture or twelve if I could figure out how to get them from my iPhone and onto here.
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052407
04/12/16 12:24 AM
04/12/16 12:24 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You might want to ask Hemi-itis.. granted his
is in a B-body but the radiator size is whats
important
wave
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052510
04/12/16 01:59 AM
04/12/16 01:59 AM
Don't take this wrong but 700 HP on the street is not a real problem to cool. I bought a new 22x19inch two core aluminum radiator from Best racing for my old pump gas Duster (it ran 180 to 200 F when crusing)up It made 727 HP on Oregon pump gas shruggy It had a Griffin 4 core cross flow brass and copper radiator of the same size in it originaly but it wouldn't keep that motor cool enough, it ran 220 F + when cruising work IHTHs
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052531
04/12/16 02:24 AM
04/12/16 02:24 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Cab- do you remember if it was cross-flow or tanks on top/bottom? Its more trying to fit it all in there with twin fans,trans cooler and radiator and grille.seems tight.Anybody use a champion radiator?
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052532
04/12/16 02:26 AM
04/12/16 02:26 AM
Richmond , Virginia
BEEQUIK Offline OP
BEEQUIK  Offline OP
Richmond , Virginia
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052572
04/12/16 04:26 AM
04/12/16 04:26 AM
The aluminum radiator had conventional tanks and outlets for the BB with the lower outlet on the drivers side and the upper outlet on the passenger side. the Griffen had side tanks with the outlet like normal BB radiators have, lower outlet on drivers side, upper centered or on the passenger side.
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052623
04/12/16 10:21 AM
04/12/16 10:21 AM
Tampa
DusterDave Offline
DusterDave  Offline
Tampa
When I had a 440 in my Duster, I used a Howe 19x28 radiator, with a pair of Perma-Cool 14" fans. 13" fans would have fit better. This pic was taken before I built a shroud, which I highly recommend. Even when I swapped to a blown 528 Hemi, I never had any cooling problems. I think I paid $200 for the rad at Summit.
Gone to the dark side with an LS3 powered '57 Chevy 210
Re: Bigblock Blower motor in an A-body-WHICH RADIATOR?? [Re: BEEQUIK] #2052624
04/12/16 10:25 AM
04/12/16 10:25 AM
Martinsville, IN
cdwmotorsports Offline
Martinsville, IN
Lots of guys on forabodiesonly.com using the Champion radiators. CC375 is the big block one most are using.
eBay-cdwmotorsports
