Re: Bigblock Blower motor in an A-body-WHICH RADIATOR??
[Re: BEEQUIK]
#2052407
04/12/16 12:24 AM
04/12/16 12:24 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You might want to ask Hemi-itis.. granted his is in a B-body but the radiator size is whats important
[Re: BEEQUIK]
#2052510
04/12/16 01:59 AM
04/12/16 01:59 AM
Posts: 43,163 Bend,OR USA
Cab_Burge
Don't take this wrong but 700 HP on the street is not a real problem to cool. I bought a new 22x19inch two core aluminum radiator from Best racing for my old pump gas Duster (it ran 180 to 200 F when crusing) It made 727 HP on Oregon pump gas It had a Griffin 4 core cross flow brass and copper radiator of the same size in it originaly but it wouldn't keep that motor cool enough, it ran 220 F + when cruising IHTHs
[Re: BEEQUIK]
#2052572
04/12/16 04:26 AM
04/12/16 04:26 AM
Cab_Burge
The aluminum radiator had conventional tanks and outlets for the BB with the lower outlet on the drivers side and the upper outlet on the passenger side. the Griffen had side tanks with the outlet like normal BB radiators have, lower outlet on drivers side, upper centered or on the passenger side.
[Re: BEEQUIK]
#2052623
04/12/16 10:21 AM
04/12/16 10:21 AM
Posts: 1,845 Tampa
DusterDave
Tampa
When I had a 440 in my Duster, I used a Howe 19x28 radiator, with a pair of Perma-Cool 14" fans. 13" fans would have fit better. This pic was taken before I built a shroud, which I highly recommend. Even when I swapped to a blown 528 Hemi, I never had any cooling problems. I think I paid $200 for the rad at Summit. [
Gone to the dark side with an LS3 powered '57 Chevy 210
[Re: BEEQUIK]
#2052624
04/12/16 10:25 AM
04/12/16 10:25 AM
Posts: 1,449 Martinsville, IN
cdwmotorsports
Martinsville, IN
Lots of guys on forabodiesonly.com using the Champion radiators. CC375 is the big block one most are using.
eBay-cdwmotorsports
