46RE trouble, again...... #2035568
03/21/16 08:31 AM
03/21/16 08:31 AM
Buford, GA
I_bleed_MOPAR Offline OP
Buford, GA
So after I took care of the broken snap rings and the governor solenoid kit for the P1757 code, the Durango drove great. Friday I noticed that when I came to a stop, it didn't downshift to 1st. You can manually shift into 1st or bump it to neutral for a second and all is well again. This is kind of intermittent- it might do it one time or it might do it 3or 4 times in a row. No codes... work
Suggestions?
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 46RE trouble, again...... [Re: I_bleed_MOPAR] #2035638
03/21/16 12:06 PM
03/21/16 12:06 PM
enfield, CT
ViperDave Offline
ViperDave  Offline
enfield, CT
did you replace the governor switch also?
67 Dart GT Vert 273/904
72 Town & Country 440/727
90 D350 reg cab dually cummins
15 Scat Pack Challenger
Re: 46RE trouble, again...... [Re: I_bleed_MOPAR] #2035750
03/21/16 02:37 PM
03/21/16 02:37 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Watch the gov sensor actual and desired pressures, if they are not the same switch em both out. Get the big BW solonoid. There is not a governor switch just a pressure/temperature sensor and variable solonoid.
Re: 46RE trouble, again...... [Re: HotRodDave] #2035836
03/21/16 04:54 PM
03/21/16 04:54 PM
Buford, GA
Buford, GA
Sounds like I need a scan tool for that. blush The kit I installed had the following in it-
This Kit Includes the following Components:
Governor Pressure Solenoid - Heavy Duty Borg Warner
Governor Pressure Transducer (Sensor) - Oem Mopar # 56028196AD / 68164850AA
Output Speed Sensor with O-Ring Installed - Oem Reference # 4800879
3-4 Accumulator Spring .126" , Upgrade
Filter
Governor Housing Base Gasket
Neoprene / Rubberized Pan Gasket (For a Quality Seal)
Tim
'71 Charger 383/727
Re: 46RE trouble, again...... [Re: I_bleed_MOPAR] #2035963
03/21/16 08:28 PM
03/21/16 08:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
That should have fixed it, perhaps a spec of dirt got into one somehow, it wouldn't take much.
Re: 46RE trouble, again...... [Re: HotRodDave] #2036040
03/21/16 10:06 PM
03/21/16 10:06 PM
Buford, GA
Buford, GA
Thanks, Dave. up
Tim
'71 Charger 383/727
Re: 46RE trouble, again...... [Re: I_bleed_MOPAR] #2036514
03/22/16 03:31 PM
03/22/16 03:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
A stuck shift valve in the VB will act just like a governor problem....no downshift when rolling to a stop.
Re: 46RE trouble, again...... [Re: John_Kunkel] #2040284
03/28/16 08:38 AM
03/28/16 08:38 AM
Buford, GA
Buford, GA
Planning on dropping the valve body and cleaning it when I have a little time.
Thanks, John. thumbs
Tim
'71 Charger 383/727
Re: 46RE trouble, again...... [Re: I_bleed_MOPAR] #2042876
03/31/16 06:37 PM
03/31/16 06:37 PM
A727Tflite Online content
A727Tflite  Online Content
What year truck is it?
And what is the part number of the transducer you installed - you show two part numbers.
Re: 46RE trouble, again...... [Re: A727Tflite] #2045731
04/03/16 10:17 PM
04/03/16 10:17 PM
Buford, GA
Buford, GA
It's a 2000. I didn't even notice the parts list showed 2 part #s. blush
As of right now, it's been shifting normally ever since I asked. Probably was a speck of dirt that passed on through as Dave said. boogie
I'll keep my fingers crossed anyway. wink
Tim
'71 Charger 383/727
