46RE trouble, again......
#2035568
03/21/16 08:31 AM
03/21/16 08:31 AM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
So after I took care of the broken snap rings and the governor solenoid kit for the P1757 code, the Durango drove great. Friday I noticed that when I came to a stop, it didn't downshift to 1st. You can manually shift into 1st or bump it to neutral for a second and all is well again. This is kind of intermittent- it might do it one time or it might do it 3or 4 times in a row. No codes... ![work work](/ubbthreads/images/graemlins/custom/work.gif) Suggestions? Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) )
Re: 46RE trouble, again......
[Re: I_bleed_MOPAR]
#2035638
03/21/16 12:06 PM
03/21/16 12:06 PM
Posts: 4,696 enfield, CT
ViperDave
enfield, CT
did you replace the governor switch also?
67 Dart GT Vert 273/904 72 Town & Country 440/727 90 D350 reg cab dually cummins 15 Scat Pack Challenger
[Re: I_bleed_MOPAR]
#2035750
03/21/16 02:37 PM
03/21/16 02:37 PM
Posts: 12,424 Kalispell Mt.
HotRodDave
Kalispell Mt.
Watch the gov sensor actual and desired pressures, if they are not the same switch em both out. Get the big BW solonoid. There is not a governor switch just a pressure/temperature sensor and variable solonoid.
[Re: HotRodDave]
#2035836
03/21/16 04:54 PM
03/21/16 04:54 PM
I_bleed_MOPAR
Buford, GA
Watch the gov sensor actual and desired pressures, if they are not the same switch em both out. Get the big BW solonoid. There is not a governor switch just a pressure/temperature sensor and variable solonoid. Sounds like I need a scan tool for that. ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) The kit I installed had the following in it- This Kit Includes the following Components:
Governor Pressure Solenoid - Heavy Duty Borg Warner
Governor Pressure Transducer (Sensor) - Oem Mopar # 56028196AD / 68164850AA
Output Speed Sensor with O-Ring Installed - Oem Reference # 4800879
3-4 Accumulator Spring .126" , Upgrade
Filter
Governor Housing Base Gasket
Neoprene / Rubberized Pan Gasket (For a Quality Seal)
Tim
[Re: I_bleed_MOPAR]
#2035963
03/21/16 08:28 PM
03/21/16 08:28 PM
HotRodDave
Kalispell Mt.
That should have fixed it, perhaps a spec of dirt got into one somehow, it wouldn't take much.
[Re: HotRodDave]
#2036040
03/21/16 10:06 PM
03/21/16 10:06 PM
I_bleed_MOPAR
Buford, GA
Thanks, Dave. ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Tim
[Re: I_bleed_MOPAR]
#2036514
03/22/16 03:31 PM
03/22/16 03:31 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
A stuck shift valve in the VB will act just like a governor problem....no downshift when rolling to a stop.
[Re: John_Kunkel]
#2040284
03/28/16 08:38 AM
03/28/16 08:38 AM
I_bleed_MOPAR
Buford, GA
Planning on dropping the valve body and cleaning it when I have a little time. Thanks, John. ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Tim
[Re: I_bleed_MOPAR]
#2042876
03/31/16 06:37 PM
03/31/16 06:37 PM
Posts: 3,102 Michigan
A727Tflite
What year truck is it? And what is the part number of the transducer you installed - you show two part numbers.
[Re: A727Tflite]
#2045731
04/03/16 10:17 PM
04/03/16 10:17 PM
I_bleed_MOPAR
Buford, GA
What year truck is it? And what is the part number of the transducer you installed - you show two part numbers. It's a 2000. I didn't even notice the parts list showed 2 part #s. ![blush blush](/ubbthreads/images/graemlins/custom/blush.gif) As of right now, it's been shifting normally ever since I asked. Probably was a speck of dirt that passed on through as Dave said. ![boogie boogie](/ubbthreads/images/graemlins/custom/boogie.gif) I'll keep my fingers crossed anyway. ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif) Tim
