Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2040257
03/28/16 03:37 AM
03/28/16 03:37 AM
San Diego, CA
mopar_man619 Offline OP
San Diego, CA
well probably not getting the 6.4 i thought i was. still in the market for a 6.1 or 5.7. wanna pull it out of a wrecked car from the salvage auction, as i feel this will be the best route. still going in an a body (67 valiant) with factory steering. what do you guys suggest as far as 5.7 or 6.1. want a turbo down the road. street/strip.
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2041336
03/29/16 06:58 PM
03/29/16 06:58 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
megasquirt can do VVT and it is amazing.
They offer a base cal and a plug 'n' play harness for 6.4Ls, too. I have 2 running but not 100% tuned yet (spring here, will hit a dyno soon). a-e-a.com .
F&B offers a bolt-on throttle body that flows more air and is cable operated, I designed it.
No major problems into A-body, shorten the steering col jacket a bit, milodon pan, TTi headers and mounts, remote filter.
Rick
Re: 6.4 hemi, what would i be getting myself into? [Re: Rick_Ehrenberg] #2041338
03/29/16 06:59 PM
03/29/16 06:59 PM
Marlboro, NY, USA
Marlboro, NY, USA
AEA also does harness and cal for 09-up VVT 5.7L, F&B has that TB, too.
Rick
Re: 6.4 hemi, what would i be getting myself into? [Re: Rick_Ehrenberg] #2041354
03/29/16 07:28 PM
03/29/16 07:28 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That site is a front page only and hasn't been updated since 2004.
That doesn't encourage me to spend money with them.
- Stu Harmon
Re: 6.4 hemi, what would i be getting myself into? [Re: feets] #2041443
03/29/16 09:58 PM
03/29/16 09:58 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I'm not sure what the A-E-A.com is, but the MS3 box is pretty up-to-date.
http://megasquirt.info/products/pro-controllers/ms3-gold-hemi/
http://www.efisource.com/shop/ms3-gen3-hemi-plug-play-gold-box/
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2065655
05/02/16 12:48 AM
05/02/16 12:48 AM
gregsdart Offline
gregsdart  Offline
Originally Posted By mopar_man619
also anybody with experience, i would be able to get this into a valiant with the stock k frame. i have read it will be a tight fit but will work with the correct oil pan.
I got a 5.7 Hemi core motor to fit in a 1965 Dodge Dart by using Jeep SRT exhaust manifolds, and coilover shocks to allow for the exhaust. I built a rack and pinion setup out of a stock K frame to take care o steering. The manifolds just make it in the early A, so there ought to be a little extra room in a 67 or newer. That is a truck oil pan , and I plan to shorten it and add back the volume with side buckets.
Re: 6.4 hemi, what would i be getting myself into? [Re: Rick_Ehrenberg] #2065661
05/02/16 01:06 AM
05/02/16 01:06 AM
Canada
onig Offline
onig  Offline
Canada
Rick
What is the part # for this throttle body?
I checked the site but could not find it.
69 Dart
Re: 6.4 hemi, what would i be getting myself into? [Re: gregsdart] #2067623
05/05/16 09:08 AM
05/05/16 09:08 AM
San Diego, CA
San Diego, CA
if you were running torsion bars would the jeep manifolds clear?
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: onig] #2072016
05/12/16 01:23 PM
05/12/16 01:23 PM
GA
roadrunninMark Offline
GA
Rick
Rick, also does this allow you to use the NAG1 trans since you are not using the electronic gas pedal? Or do you need to use that for the trans?
