Re: 6.4 hemi, what would i be getting myself into?
[Re: mopar_man619]
#2032394
03/16/16 02:30 PM
03/16/16 02:30 PM
Posts: 340 San Diego, CA
mopar_man619
San Diego, CA
also anybody with experience, i would be able to get this into a valiant with the stock k frame. i have read it will be a tight fit but will work with the correct oil pan.
1967 Plymouth Valiant Gen III Hemi 11.42@119 youtube.com/moparman619
[Re: mopar_man619]
#2032544
03/16/16 06:32 PM
03/16/16 06:32 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
You would end up with an 09 Challenger ECU since those are re-flashable, and a Hotwire harness. You will need TTI headers to keep stock K. Figure about $3K for those 2 things alone but if you want to keep it stock, thats how I would go. Just go with a 6.4/manual trans tune and run a 727/904 or about any manual trans out there.
Mopar to the bone!!!
[Re: 72Swinger]
#2032675
03/16/16 09:33 PM
03/16/16 09:33 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
My is put the whole thing in. Engine and trans. Get it running enjoy it and then down the road turbo the thing. Get it going on the stock ECM and youll be surprised at the power. Hell just going to full lenght headers will net you around 30 to 50 hp? Matt
[Re: MattW]
#2032900
03/17/16 03:29 AM
03/17/16 03:29 AM
mopar_man619
San Diego, CA
so I can use the ecu out of the donor car and trans as is. at what point do you have to send the harness out ? if i were to run a 904 ? My is put the whole thing in. Engine and trans. Get it running enjoy it and then down the road turbo the thing. Get it going on the stock ECM and youll be surprised at the power. Hell just going to full lenght headers will net you around 30 to 50 hp? Matt
[Re: 70blackfish]
#2032903
03/17/16 03:31 AM
03/17/16 03:31 AM
mopar_man619
San Diego, CA
thanks. will def be in contact with you ! I have a 6.4 in my 69 truck...i went with hotwire auto...some things can be an issue. VVT is your friend!
you can pm me if you want to ask some questions, i will give you my phone number
[Re: mopar_man619]
#2033213
03/17/16 04:05 PM
03/17/16 04:05 PM
MattW
Ontario Canada
so I can use the ecu out of the donor car and trans as is. at what point do you have to send the harness out ? if i were to run a 904 ? My is put the whole thing in. Engine and trans. Get it running enjoy it and then down the road turbo the thing. Get it going on the stock ECM and youll be surprised at the power. Hell just going to full lenght headers will net you around 30 to 50 hp? Matt Modern muscle performance has what you need to do this. I would stick with factory trans but they may be able to help you with the 904. Matt
[Re: dogdays]
#2033329
03/17/16 07:10 PM
03/17/16 07:10 PM
mopar_man619
San Diego, CA
thats what i will do. will my trans tunnel need to be modified? If you have the whole car why would you use a 904? Just checkin'
R.
[Re: dogdays]
#2036898
03/23/16 12:44 AM
03/23/16 12:44 AM
mopar_man619
San Diego, CA
so it would work ? lol That's exactly the point. The ECM uses transmission inputs as well as engine and environmental inputs.
Plus, it's an overdrive transmission and people here have said they're plenty stout.
R.
[Re: mopar_man619]
#2036971
03/23/16 05:43 AM
03/23/16 05:43 AM
72Swinger
Nebraska
The NAG's need a stand alone computer when you take away wheel sensors and speed sensors. PCS is the company IIRC. Yeah it can be done, but the donor cars wiring and computers are basically worthless unless you also use its dash,column,rear axle,abs etc.
