6.4 hemi, what would i be getting myself into? #2032390
03/16/16 02:26 PM
03/16/16 02:26 PM
San Diego, CA
mopar_man619 Offline OP
San Diego, CA
I can possibly get my hands on a 6.4 hemi out of a 2013 charger srt8 super bee that has been hit. i would love this engine for my 1967 valiant but do not want to get stuck with something i can't use. i would run it (street/strip) in stock configuration as is being everything checks out, but my ultimate plan is a little boost (turbo). no matter how much i read i still have a little fear id be stuck and unable to get it running with tons of money. anyone have things to look out for ? is the vvt an issue? will it be an issue when i add bewst ? (have semi knowledge on lockout and limiting kits). computer (which i would also get out of donor car). oh also, the engine did run and drive when it was parked. car just wrecked. any help, guidance would be greatly appreciated.
thanks
6.4 hemi
1967 Plymouth Valiant Gen III Hemi
11.42@119
youtube.com/moparman619
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2032394
03/16/16 02:30 PM
03/16/16 02:30 PM
San Diego, CA
San Diego, CA
also anybody with experience, i would be able to get this into a valiant with the stock k frame. i have read it will be a tight fit but will work with the correct oil pan.
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2032408
03/16/16 02:55 PM
03/16/16 02:55 PM
USA
hudsonhornet7x Offline
USA
Although it is easier to swap an earlier hemi I like your choice. The VVT can be locked, so that is not too big of a deal.
I would use the Holley HP fuel injection as it is self learning. Also, the 6.4 pistons are pretty fragile so it would probably be a good idea to swap them out for forged ones if you are planning a turbo setup.
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2032423
03/16/16 03:18 PM
03/16/16 03:18 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Check with HotWireAuto, they have harnesses and computers for swaps. They reflash factory computers
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2032544
03/16/16 06:32 PM
03/16/16 06:32 PM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
You would end up with an 09 Challenger ECU since those are re-flashable, and a Hotwire harness. You will need TTI headers to keep stock K. Figure about $3K for those 2 things alone but if you want to keep it stock, thats how I would go. Just go with a 6.4/manual trans tune and run a 727/904 or about any manual trans out there.
Mopar to the bone!!!
Re: 6.4 hemi, what would i be getting myself into? [Re: 72Swinger] #2032675
03/16/16 09:33 PM
03/16/16 09:33 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
My twocents is put the whole thing in. Engine and trans. Get it running enjoy it and then down the road turbo the thing.
Get it going on the stock ECM and youll be surprised at the power.
Hell just going to full lenght headers will net you around 30 to 50 hp?
Matt
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2032825
03/17/16 12:49 AM
03/17/16 12:49 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have a 6.4 in my 69 truck...i went with hotwire auto...some things can be an issue. VVT is your friend!
you can pm me if you want to ask some questions, i will give you my phone number
Re: 6.4 hemi, what would i be getting myself into? [Re: MattW] #2032900
03/17/16 03:29 AM
03/17/16 03:29 AM
San Diego, CA
San Diego, CA
so I can use the ecu out of the donor car and trans as is. at what point do you have to send the harness out ? if i were to run a 904 ?
Matt
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: 70blackfish] #2032903
03/17/16 03:31 AM
03/17/16 03:31 AM
San Diego, CA
San Diego, CA
thanks. will def be in contact with you !
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2033141
03/17/16 02:15 PM
03/17/16 02:15 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Mega squirt
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2033213
03/17/16 04:05 PM
03/17/16 04:05 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Matt
Modern muscle performance has what you need to do this.
I would stick with factory trans but they may be able to help you with the 904.
Matt
Re: 6.4 hemi, what would i be getting myself into? [Re: MattW] #2033245
03/17/16 04:52 PM
03/17/16 04:52 PM
dogdays Offline
dogdays  Offline
If you have the whole car why would you use a 904?
Just checkin'
R.
Re: 6.4 hemi, what would i be getting myself into? [Re: dogdays] #2033329
03/17/16 07:10 PM
03/17/16 07:10 PM
San Diego, CA
San Diego, CA
thats what i will do. will my trans tunnel need to be modified?
Just checkin'
R.
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2034908
03/20/16 09:53 AM
03/20/16 09:53 AM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
I believe so.
Matt
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2035267
03/20/16 08:08 PM
03/20/16 08:08 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
From what I've seen and read, stick with the 904 for the time being. When using new trans there's a very big can of worms you have to get around at this time. Go back into the other posts to read about the Nagg trans issues.
Re: 6.4 hemi, what would i be getting myself into? [Re: cudaman1969] #2035964
03/21/16 08:29 PM
03/21/16 08:29 PM
Ontario Canada
MattW Offline
MattW  Offline
Ontario Canada
Shouldn't have an issue if he is running the stock ecm?
Or am I missing something?
Re: 6.4 hemi, what would i be getting myself into? [Re: MattW] #2036495
03/22/16 03:09 PM
03/22/16 03:09 PM
dogdays Offline
dogdays  Offline
That's exactly the point. The ECM uses transmission inputs as well as engine and environmental inputs.
Plus, it's an overdrive transmission and people here have said they're plenty stout.
R.
Re: 6.4 hemi, what would i be getting myself into? [Re: dogdays] #2036898
03/23/16 12:44 AM
03/23/16 12:44 AM
San Diego, CA
San Diego, CA
so it would work ? lol
R.
11.42@119
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2036971
03/23/16 05:43 AM
03/23/16 05:43 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
The NAG's need a stand alone computer when you take away wheel sensors and speed sensors. PCS is the company IIRC. Yeah it can be done, but the donor cars wiring and computers are basically worthless unless you also use its dash,column,rear axle,abs etc.
Re: 6.4 hemi, what would i be getting myself into? [Re: mopar_man619] #2037019
03/23/16 10:45 AM
03/23/16 10:45 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
http://www.hotwireauto.com/?page=sales-nag1
Hot Wire Auto has a NAG1 set up where you don't need the dash or any of that stuff. You need some of the modules and such, it's in the link. The NAG1 is a sweet transmission, tough as nails
