Correct 4 spd pedal assembly detail...... #2038507
03/25/16 02:49 PM
03/25/16 02:49 PM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Does anybody have pics they can post of a correctly restored 4 spd pedal assembly ? Is the spring painted or natural ? How high is the black paint on the pedals ?
Re: Correct 4 spd pedal assembly detail...... [Re: THESHAKERPROJECT] #2039006
03/26/16 05:11 AM
03/26/16 05:11 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
These are photos of factory original parts from an unmolested one-owner 69 Barracuda during disassembly. The spring could be phosphated, but my best guess is bare metal. The bottom edges of the post-it notes show the limit of good spray paint coverage. Above bottom edges is overspray.
In the top photo I believe that is original (too much) factory grease. The bracket that anchors the spring at left was not designed strong enough and is deformed.
06-3 Clutch & Brake Pedals.clutch spring4.jpg06-3 Clutch & Brake Pedals.painting1.jpg06-3 Clutch & Brake Pedals.Park brake side.jpg
Re: Correct 4 spd pedal assembly detail...... [Re: THESHAKERPROJECT] #2039073
03/26/16 11:43 AM
03/26/16 11:43 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The pedals on my '69 RR had a very distinct paint line - like they were dipped.
Re: Correct 4 spd pedal assembly detail...... [Re: THESHAKERPROJECT] #2040028
03/27/16 09:55 PM
03/27/16 09:55 PM
NORTHERN VA
NORTHERN VA
I always thought the pedals were dipped too like on auto cars . I can tell by orig paint left on this 71 B Body set that the black was much higher up then in the pic above but does look like it was sprayed , not dipped . Any other orig E or B body car pics out there ?
