Re: Correct 4 spd pedal assembly detail......
[Re: THESHAKERPROJECT]
#2039006
03/26/16 05:11 AM
03/26/16 05:11 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
These are photos of factory original parts from an unmolested one-owner 69 Barracuda during disassembly. The spring could be phosphated, but my best guess is bare metal. The bottom edges of the post-it notes show the limit of good spray paint coverage. Above bottom edges is overspray.
In the top photo I believe that is original (too much) factory grease. The bracket that anchors the spring at left was not designed strong enough and is deformed.
