68 b-body channel felt #2037843
03/24/16 03:52 PM
03/24/16 03:52 PM
car48nut Offline OP
car48nut  Offline OP
Can anyone tell me what the window felt that glues into the window track is called and do they make it Thanks I am talking about the roll up windows
Re: 68 b-body channel felt [Re: car48nut] #2037965
03/24/16 07:01 PM
03/24/16 07:01 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Hmmm ... I think you're talking about the mylar strips - it doesn't glue in. Scan through the recent posts - someone else is discussing those. They are still available from dealers but the best deal for them is from Dante's. They ain't cheap for what you get !!
https://dantesparts.com/shop/mopar-catal...channel-guides/
Re: 68 b-body channel felt [Re: car48nut] #2037966
03/24/16 07:02 PM
03/24/16 07:02 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
You also need 2 for the rear pop-out windows
Re: 68 b-body channel felt [Re: Stanton] #2038062
03/24/16 09:34 PM
03/24/16 09:34 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
There are also two on the rear guides for the door glass located inside the door. They are a larger U shape but not as long.
I’m listening.
Re: 68 b-body channel felt [Re: Big Bad Bee] #2038087
03/24/16 10:03 PM
03/24/16 10:03 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
For our purposes, we call them the lock side channel runs. They are a heavy grade of rubber with a flocking that is held in place with two rivets and a glue like adhesive. Most people do not replace them when the doors are apart, but the flocking does wear away and after forty plus years, it is mostly just a piece of rubber inside the channel. The thing about these pieces is that the channel is different for the hardtops, convertibles and sedans. So if you are wanting to replace them, you will need to make sure of the correct style to order.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: 68 b-body channel felt [Re: 69bfan] #2038114
03/24/16 10:45 PM
03/24/16 10:45 PM
car48nut Offline OP
car48nut  Offline OP
what would I call them when I look for them?
Re: 68 b-body channel felt [Re: car48nut] #2038388
03/25/16 11:47 AM
03/25/16 11:47 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
the link i gave you in your other post has a blow up with the 'proper' names of all those pieces. Dixie has them all as do alot of other places.
