Re: 68 b-body channel felt
[Re: Stanton]
#2038062
03/24/16 09:34 PM
03/24/16 09:34 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
There are also two on the rear guides for the door glass located inside the door. They are a larger U shape but not as long.
I’m listening.
[Re: Big Bad Bee]
#2038087
03/24/16 10:03 PM
03/24/16 10:03 PM
Posts: 306 Georgia
69bfan
Georgia
For our purposes, we call them the lock side channel runs. They are a heavy grade of rubber with a flocking that is held in place with two rivets and a glue like adhesive. Most people do not replace them when the doors are apart, but the flocking does wear away and after forty plus years, it is mostly just a piece of rubber inside the channel. The thing about these pieces is that the channel is different for the hardtops, convertibles and sedans. So if you are wanting to replace them, you will need to make sure of the correct style to order.
www.restorationpartsandmaterials.comCorrect Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs. www.dalescudashop.comCorrect style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
