Re: Nitrous
[Re: an8sec70cuda]
#2033601
03/18/16 06:26 AM
03/18/16 06:26 AM
Posts: 1,044 Victoria, Australia
Ian
Victoria, Australia
Ran the car last night w/ the exact same setup as last time, except for the bigger -6 feed line from the bottle to the solenoid. The weather was worse last night, yet the car still ran 1 mph faster. ET was almost the same as before. Back in September in better air it ran 8.95 at 149.7 mph. Last night it went 8.96 at 150.6 mph. Much warmer and humid last night...not sure what the DA was. So maybe the bigger feed line leaned it out a little and gained me some MPH. It got quicker when I brought the nitrous in faster. For my last pass I took another degree of timing out and lowered the fuel pressure by about 1/4 lb., but the track went away. good work mate ,good to see her going quicker
Re: Moparts official power adder thread
[Re: TRENDZ]
#2034380
03/19/16 11:36 AM
03/19/16 11:36 AM
Posts: 22,728 Bitopia
jcc
Bitopia
What are the factors involved when deciding intake inlet size from say intercooler to throttle body? In this case, /6, 300hp? EFI, turbo, 4spd, 2500lb, autox/road race track car. Seems like its a restriction vs throttle response consideration, or 2.5" vs 3" tubing.
[Re: tboomer]
#2034477
03/19/16 02:09 PM
03/19/16 02:09 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better. A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost.
[Re: tboomer]
#2035783
03/21/16 03:30 PM
03/21/16 03:30 PM
Posts: 13,402 Marion, South Carolina [><]
an8sec70cuda
Monte...the more plenum volume the better w/ nitrous? Cast single 4500 manifold in question.
I experimented w/ an Indy 426-4 manifold in the past on my hemi. It's a good bit larger in both the plenum and runners than my Barton manifold. It hurt the lowend grunt significantly naturally aspirated, but I'm thinking it may be the way to go w/ nitrous?
[Re: tboomer]
#2036319
03/22/16 10:46 AM
03/22/16 10:46 AM
an8sec70cuda
I just got a set of -4/-3 lines and wow, they have a lot bigger ID than the straight -3 lines do! Surprised to see that as the only difference you can see on the outside is that the fitting on one end is the bigger -4 size.
[Re: an8sec70cuda]
#2036716
03/22/16 08:22 PM
03/22/16 08:22 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
NOS Monte
Where is the perfect spot to install O2 bung in merge collector?
What is the best retard delay for annular fogger?
Same question for plate?
Back together with Charlie's chamber softening and valve job. Only took a couple cc's out of chamber. Nothing else. 48 cc P7. Large step header sound great. Hopefully really gonna free some power on top end.
[Re: TRENDZ]
#2037204
03/23/16 03:34 PM
03/23/16 03:34 PM
Posts: 2,260 IL
furious70
IL
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better. A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost. What's the 'how' behind this, interested to know. Wasn't the conventional wisdom in Corky's book to use the smallest tubing that wouldn't result in Mach 1 speeds in the intake tract?
70 Sport Fury 68 Charger 69 Coronet 72 RR
[Re: furious70]
#2037212
03/23/16 03:47 PM
03/23/16 03:47 PM
Posts: 1,942 Metro Detroit
OUTLAWD
Metro Detroit
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better. A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost. What's the 'how' behind this, interested to know. Wasn't the conventional wisdom in Corky's book to use the smallest tubing that wouldn't result in Mach 1 speeds in the intake tract? Picture a part throttle condition, MAP is below baro, but between compressor and throttle is more or less close to baro, minus any inlet restriction dP. When you go to WOT, the larger volume will take longer to deplete before the pressure drops, whereas the smaller volume will deplete quickly. By the time this volume is depleted, the turbo should be spooled.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts 66 Belv. II - just a streetcar 88 Mustang - turbo LS beater
[Re: tboomer]
#2037224
03/23/16 03:56 PM
03/23/16 03:56 PM
OUTLAWD
Metro Detroit
N2O Question:
If I cannot get my new EFI setup to compensate for a dry shot, should I be able to use my existing fuel solenoid (E-brock RPM solenoid, unknown orifice) with 60psi fuel rail pressure from the EFI system?
Pumps should be more than enough to handle it.
[Re: OUTLAWD]
#2037313
03/23/16 06:23 PM
03/23/16 06:23 PM
jcc
Bitopia
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better. A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost. What's the 'how' behind this, interested to know. Wasn't the conventional wisdom in Corky's book to use the smallest tubing that wouldn't result in Mach 1 speeds in the intake tract? Picture a part throttle condition, MAP is below baro, but between compressor and throttle is more or less close to baro, minus any inlet restriction dP. When you go to WOT, the larger volume will take longer to deplete before the pressure drops, whereas the smaller volume will deplete quickly. By the time this volume is depleted, the turbo should be spooled. Of course with that logic, every car/motor combination would have its own "sweet Spot", based on many things, including driving style, track layout, ratios, etc, if I understand the principle proposed, which on face value, makes sense.
[Re: jcc]
#2037386
03/23/16 08:36 PM
03/23/16 08:36 PM
TRENDZ
Milwaukee WI
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better. A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost. What's the 'how' behind this, interested to know. Wasn't the conventional wisdom in Corky's book to use the smallest tubing that wouldn't result in Mach 1 speeds in the intake tract? Picture a part throttle condition, MAP is below baro, but between compressor and throttle is more or less close to baro, minus any inlet restriction dP. When you go to WOT, the larger volume will take longer to deplete before the pressure drops, whereas the smaller volume will deplete quickly. By the time this volume is depleted, the turbo should be spooled. Of course with that logic, every car/motor combination would have its own "sweet Spot", based on many things, including driving style, track layout, ratios, etc, if I understand the principle proposed, which on face value, makes sense. Think of it in extremes. No turbo in this little experiment. Lets say you put a 6 inch square box on your engine before the throttle plates. It has a dime sized hole in it. Whack the throttle open. The engine consumes the air very quickly and is very down on power. Now, put a 6 foot square box on it. Same dime sized hole. The engine will make much more power, for a longer time, before the air is depleted. Like I said extreme, but it sort of illustrates the point.
[Re: TRENDZ]
#2037498
03/23/16 11:27 PM
03/23/16 11:27 PM
jcc
Bitopia
Your example is valid and I agree, but to fill the larger box at first or after once depleted, takes a longer time, the larger the box, hence my "sweet spot" comment, correct?
[Re: tboomer]
#2040715
03/28/16 09:47 PM
03/28/16 09:47 PM
Posts: 1,267 North, Alabama
D-50
North, Alabama
Nice looking pistons and rods. About what will the compression be with those?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
[Re: D-50]
#2040720
03/28/16 09:58 PM
03/28/16 09:58 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Nice looking pistons and rods. About what will the compression be with those? I really don't know yet. I have a new set of B1 heads that I started porting but haven't finished yet with really small chambers. I will have those finished hopefully to go on this build next year. The set going on this years engine stall around 420cfm and will go higher with some more time but I want to get this engine together. Like I said earlier the pistons I have for this year will only take a recommended 250 hit MAX. Time to get my feet wet. ![](http://i753.photobucket.com/albums/xx174/jacadamore/Mobile%20Uploads/2016-02/2FD9A366-49A3-46DB-8121-C79969E66797_zpsgeazs85f.jpg)
[Re: tboomer]
#2040723
03/28/16 10:04 PM
03/28/16 10:04 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
You need to look at the pictures of Wade's heads that Charlie Buck did. You don't soften up those B-1 chambers it will be VERY timing sensitive. Also the right camshaft is a MUST. Nearly impossible to get the numbers you NEED on a standard BBM core. Needs to be 55mm
[Re: Monte_Smith]
#2040747
03/28/16 10:26 PM
03/28/16 10:26 PM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You need to look at the pictures of Wade's heads that Charlie Buck did. You don't soften up those B-1 chambers it will be VERY timing sensitive. Also the right camshaft is a MUST. Nearly impossible to get the numbers you NEED on a standard BBM core. Needs to be 55mm I'll have to try to find that post Monte but being retired on a limited budget and now 60 years old its go time. A good Friend Tom Hemphile speced a cam for me for this year so like I said I will get my feet wet. We have a small heads-up series at Quaker City called Dads Outlaw Street that my car will fit in and its mostly local low-dollar guys out for fun. Looking forward to a new challenge but my bracket car comes first. I love to race 1-2 times a week.
