Page 6 of 20 1 2 4 5 6 7 8 19 20
Re: Nitrous [Re: an8sec70cuda] #2033601
03/18/16 06:26 AM
03/18/16 06:26 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Originally Posted By an8sec70cuda
Ran the car last night w/ the exact same setup as last time, except for the bigger -6 feed line from the bottle to the solenoid.
The weather was worse last night, yet the car still ran 1 mph faster. ET was almost the same as before. Back in September in better air it ran 8.95 at 149.7 mph. Last night it went 8.96 at 150.6 mph. Much warmer and humid last night...not sure what the DA was.
So maybe the bigger feed line leaned it out a little and gained me some MPH.
It got quicker when I brought the nitrous in faster.
For my last pass I took another degree of timing out and lowered the fuel pressure by about 1/4 lb., but the track went away.
good work mate ,good to see her going quicker
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: Moparts official power adder thread [Re: TRENDZ] #2034380
03/19/16 11:36 AM
03/19/16 11:36 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
What are the factors involved when deciding intake inlet size from say intercooler to throttle body? In this case, /6, 300hp? EFI, turbo, 4spd, 2500lb, autox/road race track car. Seems like its a restriction vs throttle response consideration, or 2.5" vs 3" tubing.
Re: Moparts official power adder thread [Re: tboomer] #2034477
03/19/16 02:09 PM
03/19/16 02:09 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I personally would suggest to go with larger tubing. Larger tubing does take a bit longer to fill, but pre-boost throttle response actually gets better.
A good example would be with the old Buick Grand Nationals. You could get a kit that had a larger tube that went from the intercooler to the throttle body, and an over sized weld on elbow for the turbo side of the intercooler. It made a great improvement in the pre-boost power. Any extra time it may have taken to fill the tubing/ intercooler was more than made up for in throttle response pre-boost.
Re: Moparts official power adder thread [Re: tboomer] #2035783
03/21/16 03:30 PM
03/21/16 03:30 PM
an8sec70cuda Offline
Monte...the more plenum volume the better w/ nitrous? Cast single 4500 manifold in question.
I experimented w/ an Indy 426-4 manifold in the past on my hemi. It's a good bit larger in both the plenum and runners than my Barton manifold. It hurt the lowend grunt significantly naturally aspirated, but I'm thinking it may be the way to go w/ nitrous?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Moparts official power adder thread [Re: tboomer] #2036319
03/22/16 10:46 AM
03/22/16 10:46 AM
I just got a set of -4/-3 lines and wow, they have a lot bigger ID than the straight -3 lines do! Surprised to see that as the only difference you can see on the outside is that the fitting on one end is the bigger -4 size.
CHIP
Re: Moparts official power adder thread [Re: an8sec70cuda] #2036716
03/22/16 08:22 PM
03/22/16 08:22 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
NOS
Monte
Where is the perfect spot to install O2 bung in merge collector?
What is the best retard delay for annular fogger?
Same question for plate?
Back together with Charlie's chamber softening and valve job. Only took a couple cc's out of chamber. Nothing else. 48 cc P7. Large step header sound great. Hopefully really gonna free some power on top end.
Re: Moparts official power adder thread [Re: TRENDZ] #2037204
03/23/16 03:34 PM
03/23/16 03:34 PM
IL
furious70 Offline
furious70  Offline
IL
What's the 'how' behind this, interested to know. Wasn't the conventional wisdom in Corky's book to use the smallest tubing that wouldn't result in Mach 1 speeds in the intake tract?
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Moparts official power adder thread [Re: furious70] #2037212
03/23/16 03:47 PM
03/23/16 03:47 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Picture a part throttle condition, MAP is below baro, but between compressor and throttle is more or less close to baro, minus any inlet restriction dP. When you go to WOT, the larger volume will take longer to deplete before the pressure drops, whereas the smaller volume will deplete quickly. By the time this volume is depleted, the turbo should be spooled.
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Moparts official power adder thread [Re: tboomer] #2037224
03/23/16 03:56 PM
03/23/16 03:56 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
N2O Question:
If I cannot get my new EFI setup to compensate for a dry shot, should I be able to use my existing fuel solenoid (E-brock RPM solenoid, unknown orifice) with 60psi fuel rail pressure from the EFI system?
Pumps should be more than enough to handle it.
Re: Moparts official power adder thread [Re: OUTLAWD] #2037313
03/23/16 06:23 PM
03/23/16 06:23 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Of course with that logic, every car/motor combination would have its own "sweet Spot", based on many things, including driving style, track layout, ratios, etc, if I understand the principle proposed, which on face value, makes sense.
Re: Moparts official power adder thread [Re: jcc] #2037386
03/23/16 08:36 PM
03/23/16 08:36 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Think of it in extremes. No turbo in this little experiment. Lets say you put a 6 inch square box on your engine before the throttle plates. It has a dime sized hole in it. Whack the throttle open.
The engine consumes the air very quickly and is very down on power.
Now, put a 6 foot square box on it. Same dime sized hole. The engine will make much more power, for a longer time, before the air is depleted.
Like I said extreme, but it sort of illustrates the point.
Re: Moparts official power adder thread [Re: TRENDZ] #2037498
03/23/16 11:27 PM
03/23/16 11:27 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Your example is valid and I agree, but to fill the larger box at first or after once depleted, takes a longer time, the larger the box, hence my "sweet spot" comment, correct?
Re: Moparts official power adder thread [Re: jcc] #2037499
03/23/16 11:29 PM
03/23/16 11:29 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
agreed up
Re: Moparts official power adder thread [Re: TRENDZ] #2039156
03/26/16 02:11 PM
03/26/16 02:11 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Compression ? Again. I'm building a 413ci smallblock with large port commando heads blown with a 6-71 and to be run on E85.. I'm sure I will not go over about 16lbs boost and probably not that much. I'm looking for compression ratio recommendations. I'm leaning toward 10.5 to 11. What are your thoughts???? Thanks, Max
Re: Moparts official power adder thread [Re: tboomer] #2039774
03/27/16 03:32 PM
03/27/16 03:32 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Blue I think the combo sounds perfect. I run more compression then you with lots more boost on gas
Re: Moparts official power adder thread [Re: FastmOp] #2040670
03/28/16 09:03 PM
03/28/16 09:03 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Pretty boring on this post so I'll add some pictures for next years nitrous build. I bought these pistons last year off Jason Digby and needed a different rod length (7.150). He is making the switch over to a turbo build so I bought a low run set off of Jason. After the season if I don't find a chevy sized 4.500 stroke crank I will remove the one I'm using this year to have it cut down. By then my nitrous learning curve will have a little experience so I can let her eat. The rods showed up today.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Moparts official power adder thread [Re: tboomer] #2040715
03/28/16 09:47 PM
03/28/16 09:47 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
Nice looking pistons and rods. About what will the compression be with those?
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Moparts official power adder thread [Re: D-50] #2040720
03/28/16 09:58 PM
03/28/16 09:58 PM
PA.
"Little"John
"Little"John
PA.
I really don't know yet. I have a new set of B1 heads that I started porting but haven't finished yet with really small chambers. I will have those finished hopefully to go on this build next year. The set going on this years engine stall around 420cfm and will go higher with some more time but I want to get this engine together. Like I said earlier the pistons I have for this year will only take a recommended 250 hit MAX. Time to get my feet wet.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Moparts official power adder thread [Re: tboomer] #2040723
03/28/16 10:04 PM
03/28/16 10:04 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You need to look at the pictures of Wade's heads that Charlie Buck did. You don't soften up those B-1 chambers it will be VERY timing sensitive. Also the right camshaft is a MUST. Nearly impossible to get the numbers you NEED on a standard BBM core. Needs to be 55mm
Re: Moparts official power adder thread [Re: Monte_Smith] #2040747
03/28/16 10:26 PM
03/28/16 10:26 PM
PA.
"Little"John
"Little"John
PA.
I'll have to try to find that post Monte but being retired on a limited budget and now 60 years old its go time. A good Friend Tom Hemphile speced a cam for me for this year so like I said I will get my feet wet. We have a small heads-up series at Quaker City called Dads Outlaw Street that my car will fit in and its mostly local low-dollar guys out for fun. Looking forward to a new challenge but my bracket car comes first. I love to race 1-2 times a week.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
