Re: Mancini WP Housing and 440 Source the same quality?
[Re: Adam71Charger]
#2033435
03/17/16 10:22 PM
03/17/16 10:22 PM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Mancini has (or had) a deal on the housing, pump, and neck for a very competitive price. AND they have a 10% discount going on, I think. So there is not that much difference in price between the two.
Personally, I have had mixed success with 440 Source. Half the stuff I have bought from them has been fine. And half has been junk that they would do nothing about. If fact, they didn't even want to hear about it.
I have never had any problem with anything from Mancini. But their stuff is usually more expensive.
Good luck with whatever you decide.
Master, again and still
[Re: Adam71Charger]
#2033641
03/18/16 10:14 AM
03/18/16 10:14 AM
Posts: 543 Indiana, Just Off I-70
BradD
last I remember the 440Source housing had restrictive passages which caused hot running temps. Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
[Re: Adam71Charger]
#2033871
03/18/16 03:52 PM
03/18/16 03:52 PM
Posts: 197 Milwaukee, WI
moparjimbo
Milwaukee, WI
I have used a ton of 440source stuff my last few builds with great results. I also use a ton of Mancini parts as well. If the prices are comparable or its a name brand part I buy from Summit, Jegs, or Mancini. A ton of the dress up, fabricated, etc type parts I buy from 440source including the water pump, housing, etc.
1996 Viper GTS - UGR Twin Turbo 1500RWHP, 9.02 @ 167 on pump gas and DOT tire 1973 Challenger - 572 Indy Hemi 860HP 1975 Trailduster Convertible, 440 1967 Plymouth Fury Police Pursuit 2DR 505 Stroker 2004 Neon SRT4 modded www.milwaukeemopar.com
[Re: BradD]
#2033954
03/18/16 06:17 PM
03/18/16 06:17 PM
Posts: 1,013 LEE, MASS
TOMRR
LEE, MASS
last I remember the 440Source housing had restrictive passages which caused hot running temps. Brad I had that problem a few years back with their water pump housing when I called them on it they said did you put it on the car I said of course, they said to bad. Got a Mancini and Had No Problem I wlli never buy any thing from them again
[Re: TOMRR]
#2034098
03/18/16 10:01 PM
03/18/16 10:01 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have the Mancini pump and housing package and got their billet t-stat housing assembled with Superformance gaskets No leaks No problems in 6 years Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Adam71Charger]
#2034128
03/18/16 11:06 PM
03/18/16 11:06 PM
Posts: 259 Scatchamatoon
Saskabusa
Scatchamatoon
I bought a 440 Source housing and pump two years ago. Water passages look just like a stock housing. Motor stays nice and cool, it's a 500 hp 451 in a street car.
1974 Roadrunner
1967 Charger
