1971 Plymouth interior soft trim and paint color codes #2031599
03/15/16 12:33 PM
03/15/16 12:33 PM
Virginia
JimG Offline OP
JimG  Offline OP
Virginia
I'm building a 1971 Satellite Adam-12 squad car clone. I'd like to be as accurate as possible.
I've attempted to decode a couple of fender tags on cars that I think have the same interior color as the LAPD/Adam-12 Satellites. I came up with T7 as the interior soft trim color, which is either called Chestnut or Saddle Bronze, depending on who you believe. I came up with GT8 (or T8) as the interior paint color, which I think is called Dark Tan Poly.
I can get reproduction door panels, which are pricey. I want to be darn sure that I know what I'm talking about before dropping the coin on them. So, I have two questions:
1) Does T7 sound like a legitimate code for a brown/dark brown interior soft trim color in 1971?
2) If so, do the attached screen shots from Adam-12 appear to be T7?
Thank you!
Re: 1971 Plymouth interior soft trim and paint color codes [Re: JimG] #2031758
03/15/16 04:48 PM
03/15/16 04:48 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Re: 1971 Plymouth interior soft trim and paint color codes [Re: Morty426] #2031805
03/15/16 06:12 PM
03/15/16 06:12 PM
Virginia
JimG Offline OP
JimG  Offline OP
Virginia
Sure does Morty. Thanks for the info!
Re: 1971 Plymouth interior soft trim and paint color codes [Re: JimG] #2031872
03/15/16 08:47 PM
03/15/16 08:47 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
No problem - can't wait to see it done
Re: 1971 Plymouth interior soft trim and paint color codes [Re: Morty426] #2032173
03/16/16 04:51 AM
03/16/16 04:51 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
in those pics - it almost looks like the door panels are a third "tan" between to two colors used on the seats. Interior paint such as UDF GT8 is different than most of the other painted or molded in color parts.
L2T3 - too bad they don't specify door panels on the interior diagram
there is an AM-12 wagon in the local club, I can see if he comes to MATS this weekend & check out his interior "tans"
Re: 1971 Plymouth interior soft trim and paint color codes [Re: JimG] #2032194
03/16/16 08:25 AM
03/16/16 08:25 AM
Virginia
JimG Offline OP
JimG  Offline OP
Virginia
Thank you 6bblgt! I think I've seen pics of that wagon on the 'net. If he shows up, if you could check with him, that would be great. Also if you see him, please tell him we have a facebook page for the owners and potential owners of Adam-12 clones. If he (or you, or anyone) looks, it';s easy to find. PM me if you have trouble.
Thanks again!
