I'm building a 1971 Satellite Adam-12 squad car clone. I'd like to be as accurate as possible.
I've attempted to decode a couple of fender tags on cars that I think have the same interior color as the LAPD/Adam-12 Satellites. I came up with T7 as the interior soft trim color, which is either called Chestnut or Saddle Bronze, depending on who you believe. I came up with GT8 (or T8) as the interior paint color, which I think is called Dark Tan Poly.
I can get reproduction door panels, which are pricey. I want to be darn sure that I know what I'm talking about before dropping the coin on them. So, I have two questions:
1) Does T7 sound like a legitimate code for a brown/dark brown interior soft trim color in 1971?
2) If so, do the attached screen shots from Adam-12 appear to be T7?
Thank you!
