Page 2 of 6 1 2 3 4 5 6
Re: Good day for (street) car at the track! [Re: GY3] #2030697
03/14/16 12:58 AM
03/14/16 12:58 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Going faster is an inner evil.You sur know about those!!LMOL
Bracket racing isn't about speed,,,it about R/T"s and consistency.
Now if your an ET chaser/ tuna like me,your in deep poooooooop fan
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Good day for (street) car at the track! [Re: hemi-itis] #2030718
03/14/16 01:34 AM
03/14/16 01:34 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Now if your an ET chasre/ tuna like me,your in deeo poooooooop fan
Just looking to refine and maximize what I have. Not changing parts to chase e.t. I built what I want and it is a street car first and foremost!
Re: Good day for (street) car at the track! [Re: GY3] #2030763
03/14/16 04:31 AM
03/14/16 04:31 AM
Any muscle car that will be driven at WOT more than once needs to have way more fuel volume, supply, than it needs to insure a long life without detonation. A 5/16 pickup and gas line is probally marginal at best, 3/8 on both will be way better thumbs I put 1/2 lines and 1/2 pickupds or two 3/8 and 5/16 mixed to gether on all of my cars that I build for motors with more than 500 HP on pump gas thumbs
Re: Good day for (street) car at the track! [Re: GY3] #2031626
03/15/16 01:32 PM
03/15/16 01:32 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'd say that certainly acceptable for the first time out.
No roll bar, so I don't know how much quicker you can go before they start telling you to slow it down.
As someone who ran well into the 10's with the OE 5/16" line and a mechanical pump, my advice is.... Put a bigger line on it.
With the 383 in my car, I went from the OE 5/16" line/mechanical pump to a cell with a Mallory 140 pump and 1/2" line..... Added a fresh air hood(not sealed to the carb), and took out 100lbs........ And went from 119mph to 123mph.
All I could think of was, "I wish I had done it when I had the 448 in the car".
Re: Good day for (street) car at the track! [Re: GY3] #2031737
03/15/16 04:17 PM
03/15/16 04:17 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
that's not terrible. And you have room to grow. I wouldn't go down on the Pro's (you are talking about the radials right?) When you go WOT at idle it's like dropping the clutch at 3+K. You might sing less if you load up the converter some. I always like to come off just above idle (1200 or so) I tried everything to get my old 70 to hook, new slicks, new shocks (front and rear) and nothing seemed to work, the "butt end" lifted to much, I went with Cal-Tracks, never got to the track with them, but they seemed to work well on the street.
Coming soon!!!!
Re: Good day for (street) car at the track! [Re: GY3] #2031965
03/15/16 11:05 PM
03/15/16 11:05 PM
Chicken coop
dustergirl340 Offline
Chicken Little
Chicken Little
Chicken coop
Love that car! Husband's Challenger runs 11.7's @ 113, with 1.61 sixty foot on M/T ET street drag radials. What tires do you have? Better hook will definitely get that ET down.
Re: Good day for (street) car at the track! [Re: dustergirl340] #2031975
03/15/16 11:18 PM
03/15/16 11:18 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
M/T ET Street Pro's in 275/60/15
Re: Good day for (street) car at the track! [Re: GY3] #2031981
03/15/16 11:30 PM
03/15/16 11:30 PM
Chicken coop
Chicken Little
Chicken Little
Chicken coop
Play with that tire pressure, our Challenger actually hooks best at 18-19 PSI.
Re: Good day for (street) car at the track! [Re: dustergirl340] #2032015
03/16/16 12:01 AM
03/16/16 12:01 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
I was at 21 psi.
The car left straight and true save for the time I spun hard off the line. Very happy with that aspect..
Re: Good day for (street) car at the track! [Re: GY3] #2032045
03/16/16 12:28 AM
03/16/16 12:28 AM
Nebraska
451Cuda Offline
451Cuda  Offline
Nebraska
Originally Posted By GY3
Originally Posted By 68KillerBee
Going to Indy swap meet and posts like this are what make me go work on my car to get it going. 470" stroker with mch done up stealth heads should be a bit quicker than my old ~8.8:1 383 I had in it that ran 14.5's.
So thanks for posting! Now off to set the motor in. Then gotta switch the 8 3/4 to the strange 60 and get a driveshaft made. Pretty excited!
Haha, I have a Dana 60 waiting in the wings. May wait until Fall to see if I need to mini tub the car for traction. drive
I'll be at Mo-Kan April 9th for the Mopar event and then again for the HAMB drags. Come by and say Hi.
You can fit a 10 x 29 I bet, should be plenty
Re: Good day for (street) car at the track! [Re: GY3] #2032271
03/16/16 11:29 AM
03/16/16 11:29 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
after looking at the car you need to get the butt end down. You should also make sure you have enough front end travel. The tire size is not the problem, guys run 9's on 275 drag radials. The era of "big tire" cars is over. I'm guessing with that mph you should be in the 1.50ish 60 foot range. That's what I was shooting for.
Re: Good day for (street) car at the track! [Re: Mr.Yuck] #2032557
03/16/16 06:41 PM
03/16/16 06:41 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
That's exactly where I want to be with 60 ft.
I've flipped the front spring hangers before to lower it and may try that, but I'll have to check pinion angle.
Re: Good day for (street) car at the track! [Re: GY3] #2032624
03/16/16 07:57 PM
03/16/16 07:57 PM
North, Alabama
D-50 Offline
D-50  Offline
North, Alabama
When I put SS springs on my Demon it was jacked up in the back, It looked like crap. I put 2 in. lowering blocks under it.
1.33 60 ft,6.21 at 110.59 in the 1/8, pump gas small block,2950lbs,drag radials,mufflers and driven to track ...
Re: Good day for (street) car at the track! [Re: GY3] #2032743
03/16/16 11:21 PM
03/16/16 11:21 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
With my old 440 and a best et of 11.49 @ 116 it had a best 60 ft of 1.57 but would average around a 1.60 and sometimes hitting high 1.50's on good tracks. That was on just SS springs. I agree that when you get the hook working good you should be running 11.30's to 11.40's with the 117 mph and 60 ft's in the low 1.60's to high 1.50's. If you go to Cal Tracs and really hook it may even 60 ft better. But thats if you get real serious about going after that 60 ft. My car now 60's in the low 1.50's with a 1.50 best 60 and its just average for a 10.70 car on SS springs. Good luck with your car. up Ron
PS: D-50 thats a very nice Demon.
Re: Good day for (street) car at the track! *New best today* [Re: GY3] #2050699
04/09/16 11:29 PM
04/09/16 11:29 PM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Minor changes, dropped air pressure to 18 psi, 90/10 shocks.
It did a 11.30 @ 119 mph!
I was more than thrilled!
1.60 60 ft.
7.18 1/8
95.6 mph 1/8
Re: Good day for (street) car at the track! *New best today* [Re: GY3] #2050729
04/10/16 12:26 AM
04/10/16 12:26 AM
fullmetaljacket Offline
Get that short 6o' down to the 50's and that pup will be bottom 11's.
Re: Good day for (street) car at the track! *New best today* [Re: fullmetaljacket] #2050735
04/10/16 12:34 AM
04/10/16 12:34 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
This was leaving off idle. I tried bringing it up on the converter and it spun pretty hard.
A track like Tulsa will probably hook even better and get me in the .20's.
I didn't touch the motor all day!
Re: Good day for (street) car at the track! *New best today* [Re: GY3] #2050743
04/10/16 01:04 AM
04/10/16 01:04 AM
Try just a pound or two less on the tires and get yourself a set Calvert 90/10s up front.
Re: Good day for (street) car at the track! *New best today* [Re: fullmetaljacket] #2050751
04/10/16 01:19 AM
04/10/16 01:19 AM
Wichita
GY3 Offline OP
GY3  Offline OP
Wichita
Will do!
I was eyeing the Calverts but got a smokin' deal on these CE 3 ways.
Re: Good day for (street) car at the track! *New best today* [Re: GY3] #2050851
04/10/16 04:46 AM
04/10/16 04:46 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
1.60 60 ft.
7.18 1/8
95.6 mph 1/8
Congrats as thats very nice ! beer And you picked up some MPH. up Ron
