O/2 sensor location,where is the sweet spot???????
#2022554
03/01/16 01:28 PM
03/01/16 01:28 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I'm getting some silly readings from the O/2 sensor,the log looks more like a seismograph.I have the sensor about 8 inches from the header pipe merge in the bend inward toward the "X" . Monte said it's most likely in a turbulent location.The sensor is at the 9 o'clock position. SO where IS the sweet spot to install the sensor???
Re: O/2 sensor location,where is the sweet spot???????
[Re: hemi-itis]
#2022560
03/01/16 01:38 PM
03/01/16 01:38 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I put them in a straight run area.. about 6" after the end of the primaries.. if yu were running open headers I want 8"-10" before the end of the collector.. that way it wont back flow and pick up out side air which could give you bogus readings on shut down or a steady rpm.. make sure the sensor is pointed a little downward (on the inside) the drop off moisture when its cooling... try not to put it near the X.. being that just pulses back and forth ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: hemi-itis]
#2022570
03/01/16 01:53 PM
03/01/16 01:53 PM
Posts: 715 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
I have put sensors all over primary pipe, collector, before the merge, after and 8 inches down stream. I have never had a problem with reading jumping around. With that being said if there is high pressure hitting the O2 sensor the reading will change. On the dyno, when we do a turbo engine, I have a pressure sensor in the exhaust manifold that allows for a correction factor to be used. this is from the Daytona sensor site, they have a chart that show the pressure relationship The Bosch LSU 4 wide-band sensor is affected by exhaust pressure as shown on the graph below. The error (%) applies to the oxygen pump cell current. Note that 1 bar corresponds to normal sea level atmospheric pressure. For most performance applications, excessive exhaust back pressure is not a concern and the resulting small error can be disregarded. At high elevations, the error is also relatively small. At 10,000 feet elevation (about .68 bar), AFR values near 13.0 will be shifted up approximately +0.15 AFR. http://www.daytona-sensors.com/tech_wego.htmlhope this helps joe
Without Data, you’re just another guy with an opinion.
[Re: hemi-itis]
#2022582
03/01/16 02:17 PM
03/01/16 02:17 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
I would put your exhaust cutouts in before I moved the 02s, that back pressure could be causing the crazy readings.
68 Barracuda Formula S 340
[Re: hemi-itis]
#2022840
03/01/16 10:41 PM
03/01/16 10:41 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
The sensor is junk. You could put it on the moon and it would still read lean. Buy a new sensor, do a clean air calibration. Don't run the engine with ratios lower than 12.0:1. Read the manufacturers mounting recommendation. Mount it in a position that is least likely to get any liquid on it.
[Re: hemi-itis]
#2022883
03/01/16 11:44 PM
03/01/16 11:44 PM
Posts: 2,872 Pattison Texas
CSK
Pattison Texas
has someone been using leaded fuel. & KILLED the o2 sensor ?
[Re: CSK]
#2022885
03/01/16 11:50 PM
03/01/16 11:50 PM
hemi-itis
has someone been using leaded fuel. & KILLED the o2 sensor ? NO That was the last set,,,,,,,,,,
[Re: TRENDZ]
#2022893
03/02/16 12:04 AM
03/02/16 12:04 AM
hemi-itis
The sensor is junk. You could put it on the moon and it would still read lean. Buy a new sensor, do a clean air calibration. Don't run the engine with ratios lower than 12.0:1. Read the manufacturers mounting recommendation. Mount it in a position that is least likely to get any liquid on it. Put a new set on before parking it for the winter.
[Re: sr4440]
#2022901
03/02/16 12:14 AM
03/02/16 12:14 AM
hemi-itis
I have put sensors all over primary pipe, collector, before the merge, after and 8 inches down stream. I have never had a problem with reading jumping around. With that being said if there is high pressure hitting the O2 sensor the reading will change. On the dyno, when we do a turbo engine, I have a pressure sensor in the exhaust manifold that allows for a correction factor to be used. this is from the Daytona sensor site, they have a chart that show the pressure relationship The Bosch LSU 4 wide-band sensor is affected by exhaust pressure as shown on the graph below. The error (%) applies to the oxygen pump cell current. Note that 1 bar corresponds to normal sea level atmospheric pressure. For most performance applications, excessive exhaust back pressure is not a concern and the resulting small error can be disregarded. At high elevations, the error is also relatively small. At 10,000 feet elevation (about .68 bar), AFR values near 13.0 will be shifted up approximately +0.15 AFR. http://www.daytona-sensors.com/tech_wego.htmlhope this helps joe What's the difference between pressure & back pressure in the 4 inch pipe??
![Name: 2.17.16 008.jpg
ID: 231407 2.17.16 008.jpg](/ubbthreads/ubbthreads.php/ubb/download/Number/231407/filename/2.17.16 008.jpg)
[Re: Bad340fish]
#2022912
03/02/16 12:25 AM
03/02/16 12:25 AM
hemi-itis
I would put your exhaust cutouts in before I moved the 02s, that back pressure could be causing the crazy readings. Shopping for pipe & v bands to fab cut outs ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: hemi-itis]
#2022921
03/02/16 12:31 AM
03/02/16 12:31 AM
Posts: 7,506 Az
Crizila
Az
Could be a wiring problem - loose / bad ground can do that.
Fastest 300
[Re: Crizila]
#2022926
03/02/16 12:43 AM
03/02/16 12:43 AM
hemi-itis
Could be a wiring problem - loose / bad ground can do that. ![work work](/ubbthreads/images/graemlins/custom/work.gif) MMMMMMM
[Re: Crizila]
#2023224
03/02/16 03:50 PM
03/02/16 03:50 PM
sr4440
Central TEXAS!!!!
Could be a wiring problem - loose / bad ground can do that. Bit confused by this, with no volts the O2 sensor (mine) will read 10.4 AFR and with full voltage (5 volts) it will read 19.5. So if it is a loose ground, I would expect a rich reading followed by a lean spike when it reconnected (maybe?). Joe
[Re: hemi-itis]
#2023238
03/02/16 04:09 PM
03/02/16 04:09 PM
TRENDZ
Milwaukee WI
The sensor is junk. You could put it on the moon and it would still read lean. Buy a new sensor, do a clean air calibration. Don't run the engine with ratios lower than 12.0:1. Read the manufacturers mounting recommendation. Mount it in a position that is least likely to get any liquid on it. Put a new set on before parking it for the winter. A new "set"? Do you have 2 sensors? Did you get the same results with the new sensor(s)? I assume the wb control box has a +5v out. Are you also using a shared SIGNAL ground?
[Re: TRENDZ]
#2023379
03/02/16 07:45 PM
03/02/16 07:45 PM
hemi-itis
The sensor is junk. You could put it on the moon and it would still read lean. Buy a new sensor, do a clean air calibration. Don't run the engine with ratios lower than 12.0:1. Read the manufacturers mounting recommendation. Mount it in a position that is least likely to get any liquid on it. Put a new set on before parking it for the winter. A new "set"? Do you have 2 sensors? Did you get the same results with the new sensor(s)? I assume the wb control box has a +5v out. Are you also using a shared SIGNAL ground? Have not been out yet with the new pair of Bosch sensors. Not sure on the shared signal ground,,,,,,,,,,
[Re: sr4440]
#2023380
03/02/16 07:50 PM
03/02/16 07:50 PM
hemi-itis
Could be a wiring problem - loose / bad ground can do that. Bit confused by this, with no volts the O2 sensor (mine) will read 10.4 AFR and with full voltage (5 volts) it will read 19.5. So if it is a loose ground, I would expect a rich reading followed by a lean spike when it reconnected (maybe?). Joe You might be in the same boat,,,,,,,,,,,
[Re: hemi-itis]
#2024101
03/03/16 10:12 PM
03/03/16 10:12 PM
TRENDZ
Milwaukee WI
Really just shooting in the dark here. I cant tell scale/ value without a ref point. You say you have 2 sensors. I see the other sensor is showing close to the same value at the cursor time line. As a trend, are they both reading the same values? If so, I guess my bad sensor theory is out the window. Are your sensor outputs calibrated correctly to your logger? Many WB controllers have configurable outputs. I usually set the low voltage(rich) to .5 volts 10:1 a/f ratio. Then set my high voltage(lean) to 4.5 volts 20:1 a/f ratio. This gives wiggle room when setting the logger/ecu input values. There are very few instances when I see NO offset voltage between output and input readings on two separate devices. I check the offset amount by setting the wideband controller to send out a straight line voltage, regardless of a/f ratio. As an example... 10:1 a/f = .5 volts 20:1 a/f = .5 volts Now your wideband should be outputting .5 volts no matter what the ratio is. Check your datalog. If the voltage doesn't read .5 volts, you need to mathematically change either the output voltage, or the read value. Do the same with the high voltage... 10:1 a/f = 4.5 volts 20:1 a/f = 4.5 volts Same deal. I keep that .5 volt window on the high and low side for offset changes. If you don't need the "windows" on the high or low side, you can widen the voltage swings(.2 volts-4.8 volts) to get better resolution. The reason I asked about sensor ground commonality, is there are frequently these ground offsets. Some manufaturers dont want other devices to share, and some do.
[Re: hemi-itis]
#2024230
03/04/16 01:43 AM
03/04/16 01:43 AM
hemi-itis
At his point,I must verify the grounds for the o/2s and see it the new sensors give a better readout.I figure 2s or 3 passes to verify where I left off last.Then open the cut outs and see what happens. Took a few more pics and must figure out how I want to fab the cutouts.
[Re: hemi-itis]
#2024646
03/04/16 08:15 PM
03/04/16 08:15 PM
Posts: 8,186 Plymouth, MI
Blusmbl
Plymouth, MI
Listen to what Trendz wrote. Others have mentioned there is no way the car can run at 19:1 a/f under load, and both sensors are reading lean. There is likely a wiring problem, and you can start by checking the voltage being read at your data acquisition unit.
