Page 4 of 4 1 2 3 4
Re: Finally got my 8 sec slip [Re: WHITEDART] #2021920
02/29/16 04:00 PM
02/29/16 04:00 PM
gregsdart Offline
gregsdart  Offline
Congrats! That is excellent performance. And on pump gas to boot!
Re: Finally got my 8 sec slip [Re: WHITEDART] #2021965
02/29/16 05:20 PM
02/29/16 05:20 PM
an8sec70cuda Offline
Awesome! Congrats on the 8 sec pass!!
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Finally got my 8 sec slip [Re: WHITEDART] #2022058
02/29/16 08:19 PM
02/29/16 08:19 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Originally Posted By WHITEDART
3080 lb power glide with the set of Brett Miller baby 8s
That is flying, Congrats. :-}
But what is a set of Brett Miller baby 8,s
Also agree that the DA isn't great compared to around here. Witch makes your run even more impressive.
my W8 were an odd ball set. I was not 100% on what they were originally built 4.but when I got them they were set up with a fresh set of titanium 2.15 intake valves.which is about the smallest that I have heard of most commonly they would use 2.18---- 2.25 Brett has a really big port that goes into these heads. But it would have require me to buy another set of intake valves which I didn't want to do at the time. What I will tell you Bretts cylinder heads make killer horsepower and carry really well and you don't have to turn them to the moon.....thanks again Brett
Correction. Many W8's made big hp. Patterson, Eatman, Davis all who used CFE. Brett's heads make torque. It takes torque to make hp. With a given torque # the higher the rpm you can hold most of it the more hp you make. When an engine makes big torque leading to hp at a lower rpm it runs better et.
Example two cars. One makes 900hp at 9k with only making a tic over 600ft. Lbs.at 7,600. Another car same converter weight everything that makes 10 lbs more torque and nets the same hp at 8,500 will run faster. You need torque or you will be in a terrible search to find that perfect converter. For most of us on a budget unobtainable.
You find some 60ft. and she'll fly. Your rear half is a challenge. My lack of torque wazeka mine.
Re: Finally got my 8 sec slip [Re: WHITEDART] #2022241
02/29/16 11:56 PM
02/29/16 11:56 PM
In a house near you
Street Monkies Offline
In a house near you
Bigger isn't always better. For this particular combination maybe the way the heads are set up is the best match, and will work better than the bigger valves/port.
Re: Finally got my 8 sec slip [Re: Street Monkies] #2022256
03/01/16 12:17 AM
03/01/16 12:17 AM
PA
W5DART66 Offline
W5DART66  Offline
PA
BIGGER is better.
This is not a small block it's 440ci
It needs a 2.200+ intake valve and 3.3" min cross section.
And it don't have that yet....
Re: Finally got my 8 sec slip [Re: W5DART66] #2022258
03/01/16 12:20 AM
03/01/16 12:20 AM
SoCal
Brian Hafliger Offline
SoCal
BIGGER is better.
Yet! laugh2
Brian Hafliger
Re: Finally got my 8 sec slip [Re: W5DART66] #2022267
03/01/16 12:26 AM
03/01/16 12:26 AM
Glendora Ca.
Just-a-dart Offline
Just-a-dart  Offline
Glendora Ca.
BIGGER is better.
Patience Brett you and I both know at some point BIG will find it's way on his car, just a matter of time and money laugh2
"Just a Bracket car dressed up like a streetcar"
Re: Finally got my 8 sec slip [Re: Just-a-dart] #2022541
03/01/16 01:11 PM
03/01/16 01:11 PM
bean town ....Ca
W
WHITEDART Offline OP
W
bean town ....Ca
Yes I can see 15 to 1.and big ports and a big intake in my future. And some q16
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Finally got my 8 sec slip [Re: WHITEDART] #2022857
03/01/16 11:06 PM
03/01/16 11:06 PM
SoCal
SoCal
Brian Hafliger
Re: Finally got my 8 sec slip [Re: WHITEDART] #2023370
03/02/16 07:13 PM
03/02/16 07:13 PM
Out West
408strokerdart Offline
Out West
Yes.....and that will equal 8.60's. Just ask me how I know. LOL.
Congrats on the nice runs. Glad it's performing well for you.
Re: Finally got my 8 sec slip [Re: 408strokerdart] #2025413
03/06/16 01:09 AM
03/06/16 01:09 AM
Mobile Alabama
SB412DUSTER Offline
SB412DUSTER  Offline
Mobile Alabama
Congrats.
Re: Finally got my 8 sec slip [Re: SB412DUSTER] #2025906
03/06/16 07:57 PM
03/06/16 07:57 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Good running setup!
Page 4 of 4 1 2 3 4
