8 3/4 axle bearing collar only?. #2016283
02/20/16 09:12 PM
02/20/16 09:12 PM
AZ - The "dry heat" state
71autoxr Offline OP
71autoxr  Offline OP
i am in need of a collar for a mopar 8 3/4 axle bearing, the part that is press fit to hold the bearing to the shaft. i have new bearings and every thing else i need. i am unable to locate just the collar. does it exist just by itself. i hate to have to buy another set of bearings just to get the collar. yes i have checked local auto parts stores, as well as several online sources. if anyone has a source or a part number i would appreciate it.
68 AMX mopars red headed stepchild
69 Dart GT Convertible 340 4 speed
71 Challenger - looks like the avatar!
Re: 8 3/4 axle bearing collar only?. [Re: 71autoxr] #2016293
02/20/16 09:37 PM
02/20/16 09:37 PM
Yes, Email the Doc (Doctor Diff that is)
Re: 8 3/4 axle bearing collar only?. [Re: RapidRobert] #2016559
02/21/16 01:00 PM
02/21/16 01:00 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: 8 3/4 axle bearing collar only?. [Re: I_bleed_MOPAR] #2017857
02/23/16 02:18 AM
02/23/16 02:18 AM
71autoxr Offline OP
71autoxr  Offline OP
The doc is out on weekends and I was looking to source one local to finish a job. My Timken set originated from doc, and i buggered up the collar. An email and $10 I have a new one on the way. FWIW no one else can provide one, I believe I exhausted all options. Thanks all.
Re: 8 3/4 axle bearing collar only?. [Re: 71autoxr] #2017987
02/23/16 12:40 PM
02/23/16 12:40 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
The bearings you bought should have came with new collars , every set I have ever bought did.
I have never seen the collars sold separately .
Re: 8 3/4 axle bearing collar only?. [Re: JohnRR] #2018021
02/23/16 01:28 PM
02/23/16 01:28 PM
Ky
jt4406 Offline
jt4406  Offline
Ky
Here's a link to one of my old posts about dana 60 axle bearings. ( https://board.moparts.org/ubbthreads/ubbt....html#Post12625 ) I bought a locking ring from A&W Bearing in Texas ( http://www.awbearings.com/ )back in 04, so I can't say if they are still available, or are available at all for a 8 &3/4. Good luck. Jess
Yeah, it's hopped up to over 160...
Re: 8 3/4 axle bearing collar only?. [Re: jt4406] #2018308
02/23/16 09:01 PM
02/23/16 09:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Two numbers I have for the bearing collars are Timken K-108601 and BCA R-201047
