8 3/4 axle bearing collar only?.
#2016283
02/20/16 09:12 PM
02/20/16 09:12 PM
Posts: 752 AZ - The "dry heat" state
71autoxr
i am in need of a collar for a mopar 8 3/4 axle bearing, the part that is press fit to hold the bearing to the shaft. i have new bearings and every thing else i need. i am unable to locate just the collar. does it exist just by itself. i hate to have to buy another set of bearings just to get the collar. yes i have checked local auto parts stores, as well as several online sources. if anyone has a source or a part number i would appreciate it.
68 AMX mopars red headed stepchild 69 Dart GT Convertible 340 4 speed 71 Challenger - looks like the avatar!
Re: 8 3/4 axle bearing collar only?.
[Re: 71autoxr]
#2016293
02/20/16 09:37 PM
02/20/16 09:37 PM
RapidRobert
Yes, Email the Doc (Doctor Diff that is)
[Re: I_bleed_MOPAR]
#2017857
02/23/16 02:18 AM
02/23/16 02:18 AM
71autoxr
The doc is out on weekends and I was looking to source one local to finish a job. My Timken set originated from doc, and i buggered up the collar. An email and $10 I have a new one on the way. FWIW no one else can provide one, I believe I exhausted all options. Thanks all.
[Re: 71autoxr]
#2017987
02/23/16 12:40 PM
02/23/16 12:40 PM
Posts: 74,979 U.S.S.A.
JohnRR
U.S.S.A.
The bearings you bought should have came with new collars , every set I have ever bought did.
I have never seen the collars sold separately .
[Re: jt4406]
#2018308
02/23/16 09:01 PM
02/23/16 09:01 PM
Posts: 25,757 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Two numbers I have for the bearing collars are Timken K-108601 and BCA R-201047
