Need a little help from Techs #201578
01/22/09 10:15 PM
01/22/09 10:15 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Have a no spark condition on Sons 1999 Sebring LXI coupe. We have the 5 volt signal from the cam and crank sensors while rotating the engine with a ratchet. We also have 12 volts to the distributor while cranking the engine over. NO SPARK! We have rang out the wires from the 6 pin distributor plug back to the pcm and the ground, all are good. I'm stummped! Could there be something in the security system keeping the pcm from firing the distributor driver? Thanks,
Re: Need a little help from Techs [Re: momopar] #201579
01/23/09 09:54 PM
01/23/09 09:54 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Is this the 2.5 V6 or the 2.7 ?? Ron
Re: Need a little help from Techs [Re: 383man] #201580
01/23/09 10:26 PM
01/23/09 10:26 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
"Coupe" would be the M-itsabitchi = 2.5 V-6
Two things I do... smack the relay bank up on the fire wall (drivers side) while cranking. If that doesn't work I throw in the "good" distributer I have. IMHO diag sucked for those cars.
Re: Need a little help from Techs [Re: J_BODY] #201581
01/24/09 12:07 AM
01/24/09 12:07 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I agree and I have put a good number of dist in them. They actually have the coil and an igniter in the dist also. Ron
Re: Need a little help from Techs [Re: 383man] #201582
01/25/09 07:57 PM
01/25/09 07:57 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
Thanks, guys,
I have come to the conclusion I will Need to change out the distributor. I have it sitting right here in front of me. I have checked the primary and secondary of coil and it checks out also coil tower to pin 11 or 12 also checks out. I did a bench test on the transistor that is inconclusive(don't have the proper analog meter) I spent a good hour researching replacement transistors and can only find them in lots of 100 or more. Seems like a scam, $10 part bad and have to replace the whole unit. It is what it is, too cold right now to mess with it for a few days. Again thanks for the help. Mo
Oh yeah, jbody is right it's the 2.5 mitsubitchy engine
Re: Need a little help from Techs [Re: momopar] #201583
01/25/09 08:13 PM
01/25/09 08:13 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Have you tried Radio shack for the transistor you need?
Re: Need a little help from Techs [Re: stumpy] #201584
01/25/09 08:32 PM
01/25/09 08:32 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
It may be that they would have one. But I can't find the data sheet so substitution would be an SWAG at best. This is a IGBT type (insulated gate bi-polar transistor) I would guess it has some kind of diode built in to prevent feedback from frying the PCM.
Re: Need a little help from Techs [Re: momopar] #201585
01/25/09 09:21 PM
01/25/09 09:21 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
What is the # of the transistor you need? I work in the medical electronics field, and know a few sources.
It's Swifty! Swifty, you toad sucker!
Re: Need a little help from Techs [Re: zrxkawboy] #201586
01/25/09 09:24 PM
01/25/09 09:24 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
The number on it is Mitsubishi pn M67580. Thanks
Re: Need a little help from Techs [Re: momopar] #201587
01/26/09 08:18 AM
01/26/09 08:18 AM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
That # doesn't cross in any of the sources I know. I imagine you've seen this thread? http://www.mx6.com/forums/2g-mx6-general/75053-distributor-transisitor-part-number.html
Have you ever read Dr. Jacob's book on ignitions? IIRC, it contains instructions on substituting a common Mopar ECU in cases like this. I can look for my copy tonight, or someone else may have a copy handy.
Re: Need a little help from Techs [Re: zrxkawboy] #201588
01/26/09 09:46 AM
01/26/09 09:46 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I forget about thinking outside the box on things like this. A guy I worked for got a Yugo for free. Couldn't get parts for it. He ended up using the base of an old GM HEI distrib he had laying around and used that to "ignite" the ignition system. Used that pos for a parts runner. Another fave of mine was back in the day using the old school mopar voltage regulator to get the charging systems working on trucks that the PCM driver for full field died on. I would be very interested in seeing that conversion. And FWIW I've run into a couple "reman" distributers (aftermarket) that were bad out of the box. We pretty much stick to selling the Chrysler one which means when the customer sees the price they tow it elsewhere.
Re: Need a little help from Techs [Re: zrxkawboy] #201589
01/26/09 06:26 PM
01/26/09 06:26 PM
NE Indiana
momopar Offline OP
momopar  Offline OP
NE Indiana
   Those transistors appear to only be sold in large bulk quantity. I think I found one that may work., It is in the Mouser catalog. I will check with our electonics guru. The weird thing is we have 2 distributors and both check out everywhere but the transistor. Seems like a 4 dollar chip is the weak link.
Re: Need a little help from Techs [Re: momopar] #201590
01/29/09 11:46 PM
01/29/09 11:46 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
Here's the schematic.
4984835-ignition.pdf (221 downloads)
