1968 Big Block Throttle Return Spring Bracket #2011995
02/14/16 09:28 PM
02/14/16 09:28 PM
Akron, Ohio
VegasCharger Offline OP
Akron, Ohio
Hello all, 1968 BB: Did the factory make a different type of throttle return spring bracket if the car came equipped with A/C? My 68 Charger 383-4 came with A/C and it has this bracket (see pic #1). But I was told that it uses this bracket (see pic #2). My bracket doesn't appear to be modified or hacked if you look at the edges, so it does look like it was from the factory.
Anyone seen these brackets (pic #1) before?
Thanks in advance!!!
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012078
02/14/16 10:50 PM
02/14/16 10:50 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I had bracket #2 on my '70 383 with factory air conditioning.
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012139
02/15/16 12:10 AM
02/15/16 12:10 AM
W
Wagonman1967 Offline
W
Bracket #2 68 R/R 383 no ac,dont know if it is correct as car came in boxes and engine is a 70.
1968 Bronze Metalic Road Runner
!967 Malibu Wagon Original 4sd w/air
2001 Dodge Ram 4wd
1985 GMC K1500 4in lift
1993 Honda Civic W 350k Beater
2003 Honda VTX 1800 Bagger
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012211
02/15/16 02:16 AM
02/15/16 02:16 AM
Akron, Ohio
Akron, Ohio
Thanks Pynzo & Wagonman1967 for the replies.
Anyone else?
Re: 1968 Big Block Throttle Return Spring Bracket [Re: Pynzo] #2012229
02/15/16 02:52 AM
02/15/16 02:52 AM
Dayton, WA
wesgtx440 Offline
wesgtx440  Offline
Dayton, WA
Bracket #2 is not correct for a 70 car. 70 used a bracket with a hole in it for the pcv hose to pass through. Bracket #2 is the non a/c 68-69 style.
68 Charger R/T 440 auto
Re: 1968 Big Block Throttle Return Spring Bracket [Re: wesgtx440] #2012239
02/15/16 03:06 AM
02/15/16 03:06 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
#2 is on my 68 big block Dart
Abe Lincoln
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012349
02/15/16 12:23 PM
02/15/16 12:23 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
http://www.herbsparts.com/proddetail.asp?prod=452
Herb's has your bracket listed as correct fot '66-'68
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012763
02/15/16 10:42 PM
02/15/16 10:42 PM
Troy,MI
Siba Offline
Siba  Offline
Troy,MI
I have neither on c body 69 big block. Throttle return spring goes to the back of compressor mounting bracket. There is a small bracket that bolts to it with a hole for the spring. The bracket changes location depending on 2 or 4 barrel (383), 440 has one location for the bracket. (Wish I could add a picture to this new format)
Re: 1968 Big Block Throttle Return Spring Bracket [Re: Pynzo] #2012785
02/15/16 11:06 PM
02/15/16 11:06 PM
Akron, Ohio
Akron, Ohio
Thanks for that. Although slightly different than mine with the curved edges as mine is straight. But the same principle. I can assume that mine is original.
Thanks again.
Re: 1968 Big Block Throttle Return Spring Bracket [Re: Siba] #2012794
02/15/16 11:16 PM
02/15/16 11:16 PM
Akron, Ohio
Akron, Ohio
Yea it's a bit of a challenge. You have to use a web pic host like Photobucket or Tinypic.com to name a few. Then you have to copy and paste the picture's direct link provided by the web host to the "enter image" icon here in the message field.
Feel free to ask any questions about this.
Thanks for your reply.
Re: 1968 Big Block Throttle Return Spring Bracket [Re: VegasCharger] #2012821
02/15/16 11:37 PM
02/15/16 11:37 PM
Cincinnati Ohio USA
Moeggenpar Offline
Moeggenpar  Offline
Cincinnati Ohio USA
#1 is the same bracket on my 68' Charger 3834V with AC
