Re: 1968 Big Block Throttle Return Spring Bracket
[Re: VegasCharger]
#2012139
02/15/16 12:10 AM
02/15/16 12:10 AM
Posts: 114 Oregon
Wagonman1967
Bracket #2 68 R/R 383 no ac,dont know if it is correct as car came in boxes and engine is a 70.
1968 Bronze Metalic Road Runner !967 Malibu Wagon Original 4sd w/air 2001 Dodge Ram 4wd 1985 GMC K1500 4in lift 1993 Honda Civic W 350k Beater 2003 Honda VTX 1800 Bagger
[Re: Pynzo]
#2012229
02/15/16 02:52 AM
02/15/16 02:52 AM
Posts: 290 Dayton, WA
wesgtx440
Dayton, WA
I had bracket #2 on my '70 383 with factory air conditioning. Bracket #2 is not correct for a 70 car. 70 used a bracket with a hole in it for the pcv hose to pass through. Bracket #2 is the non a/c 68-69 style.
68 Charger R/T 440 auto
[Re: wesgtx440]
#2012239
02/15/16 03:06 AM
02/15/16 03:06 AM
Posts: 16,155 Mesa, Arizona
dart4forte
Mesa, Arizona
#2 is on my 68 big block Dart
Abe Lincoln
[Re: Pynzo]
#2012785
02/15/16 11:06 PM
02/15/16 11:06 PM
Posts: 367 Akron, Ohio
VegasCharger
Akron, Ohio
Thanks for that. Although slightly different than mine with the curved edges as mine is straight. But the same principle. I can assume that mine is original. Thanks again.
[Re: Siba]
#2012794
02/15/16 11:16 PM
02/15/16 11:16 PM
VegasCharger
Akron, Ohio
I have neither on c body 69 big block. Throttle return spring goes to the back of compressor mounting bracket. There is a small bracket that bolts to it with a hole for the spring. The bracket changes location depending on 2 or 4 barrel (383), 440 has one location for the bracket. (Wish I could add a picture to this new format) Yea it's a bit of a challenge. You have to use a web pic host like Photobucket or Tinypic.com to name a few. Then you have to copy and paste the picture's direct link provided by the web host to the "enter image" icon here in the message field. Feel free to ask any questions about this. Thanks for your reply.
