MP bolt in frame connector question #2008141
02/08/16 08:07 PM
02/08/16 08:07 PM
bethlehem pa
mikemee1331 Offline OP
bethlehem pa
in a 1969 B-body, do they require any shenanigans sawzall with the parking brake cable? work
Re: MP bolt in frame connector question [Re: mikemee1331] #2010654
02/12/16 07:18 PM
02/12/16 07:18 PM
bethlehem pa
bethlehem pa
bump
Re: MP bolt in frame connector question [Re: mikemee1331] #2010661
02/12/16 07:24 PM
02/12/16 07:24 PM
Marshall TX
Texas383 Offline
Texas383  Offline
Marshall TX
I installed mine with no issues/alterations: 1969 Super Bee.
1969 Y2 Super Bee
1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
Re: MP bolt in frame connector question [Re: Texas383] #2010732
02/12/16 09:17 PM
02/12/16 09:17 PM
bethlehem pa
bethlehem pa
awesome and thanks for the reply! are you happy with them?
Re: MP bolt in frame connector question [Re: Texas383] #2010884
02/13/16 12:54 AM
02/13/16 12:54 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Same here.
Re: MP bolt in frame connector question [Re: Dabee] #2010895
02/13/16 01:34 AM
02/13/16 01:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
same here except I welded mine in.
Re: MP bolt in frame connector question [Re: bonefish] #2010985
02/13/16 10:01 AM
02/13/16 10:01 AM
bethlehem pa
bethlehem pa
that my plan once i know i have them installed correctly. thumbs
Re: MP bolt in frame connector question [Re: mikemee1331] #2011157
02/13/16 04:32 PM
02/13/16 04:32 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
You can easily make your own for 20 bucks if you have a welder, tape measure, grinder and cutoff wheel. After I received my Competition Engineering connectors fifteen years ago, I told myself, never again would I pay 150 bucks for what is nothing more than two four foot lengths of 1.5x2 with a flat plate on one end and a simple three sided box on the other.
Re: MP bolt in frame connector question [Re: forphorty] #2011184
02/13/16 05:04 PM
02/13/16 05:04 PM
bethlehem pa
bethlehem pa
no welder, no skills wrench. my plan is to install these myself so i know my doors shut right then have them welded biggrin
Re: MP bolt in frame connector question [Re: mikemee1331] #2011202
02/13/16 05:35 PM
02/13/16 05:35 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
up I hear ya. I'm mostly lacking in social skills. grin
Re: MP bolt in frame connector question [Re: mikemee1331] #2011439
02/13/16 11:35 PM
02/13/16 11:35 PM
USA
JoesMopar Offline
JoesMopar  Offline
USA
I am extremely interested in this topic...I have a '69 Charger I want to put them in. Please let us know how it goes and any pics would be greatly appreciated. thumbs
Re: MP bolt in frame connector question [Re: mikemee1331] #2011664
02/14/16 12:20 PM
02/14/16 12:20 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I installed them on my Duster, easy to install and I plan on having my buddy weld them on next time my car is in his garage.
Re: MP bolt in frame connector question [Re: JoesMopar] #2011676
02/14/16 12:40 PM
02/14/16 12:40 PM
bethlehem pa
bethlehem pa
will do! won't be for awhile though. late springish
Re: MP bolt in frame connector question [Re: mikemee1331] #2011686
02/14/16 01:12 PM
02/14/16 01:12 PM
Innisfil Ontario Canada
Mogre Offline
Mogre  Offline
I have welded in the MP bolt in units in my Charger. The car must be sitting on all four tires when welded. I went to a muffler shop. There is no interference with the e brake cable. Made a difference in the ride over bumps.
Re: MP bolt in frame connector question [Re: mikemee1331] #2015427
02/19/16 02:10 PM
02/19/16 02:10 PM
Marshall TX
Texas383 Offline
Texas383  Offline
Marshall TX
Quite happy. I bolted mine in originally then had someone weld them later. You want the car to be as level and straight as possible when they get welded.
It gave the car more stability.
1969 Y2 Super Bee
Re: MP bolt in frame connector question [Re: mikemee1331] #2015730
02/19/16 11:18 PM
02/19/16 11:18 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You'll want to go back in later and weld these in. A component like this really should be burned in to reduce compliance.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
