Re: MP bolt in frame connector question
[Re: mikemee1331]
#2010661
02/12/16 07:24 PM
02/12/16 07:24 PM
Posts: 678 Marshall TX
Texas383
Marshall TX
I installed mine with no issues/alterations: 1969 Super Bee.
1969 Y2 Super Bee 1959 Coronet 4 dr Sedan
~ I intend to live forever...so far so good! ~
TO GOD BE THE GLORY!!
[Re: Texas383]
#2010884
02/13/16 12:54 AM
02/13/16 12:54 AM
Posts: 3,426 Dandridge TN
Dabee
Dandridge TN
I installed mine with no issues/alterations: 1969 Super Bee. Same here.
[Re: mikemee1331]
#2011157
02/13/16 04:32 PM
02/13/16 04:32 PM
Posts: 1,456 oklahoma
forphorty
oklahoma
same here except I welded mine in. that my plan once i know i have them installed correctly. You can easily make your own for 20 bucks if you have a welder, tape measure, grinder and cutoff wheel. After I received my Competition Engineering connectors fifteen years ago, I told myself, never again would I pay 150 bucks for what is nothing more than two four foot lengths of 1.5x2 with a flat plate on one end and a simple three sided box on the other.
[Re: forphorty]
#2011184
02/13/16 05:04 PM
02/13/16 05:04 PM
Posts: 4,154 bethlehem pa
mikemee1331
bethlehem pa
same here except I welded mine in. that my plan once i know i have them installed correctly. You can easily make your own for 20 bucks if you have a welder, tape measure, grinder and cutoff wheel. After I received my Competition Engineering connectors fifteen years ago, I told myself, never again would I pay 150 bucks for what is nothing more than two four foot lengths of 1.5x2 with a flat plate on one end and a simple three sided box on the other. no welder, no skills . my plan is to install these myself so i know my doors shut right then have them welded
[Re: mikemee1331]
#2011202
02/13/16 05:35 PM
02/13/16 05:35 PM
forphorty
oklahoma
same here except I welded mine in. that my plan once i know i have them installed correctly. You can easily make your own for 20 bucks if you have a welder, tape measure, grinder and cutoff wheel. After I received my Competition Engineering connectors fifteen years ago, I told myself, never again would I pay 150 bucks for what is nothing more than two four foot lengths of 1.5x2 with a flat plate on one end and a simple three sided box on the other. no welder, no skills . my plan is to install these myself so i know my doors shut right then have them welded I hear ya. I'm mostly lacking in social skills.
[Re: mikemee1331]
#2011664
02/14/16 12:20 PM
02/14/16 12:20 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
I installed them on my Duster, easy to install and I plan on having my buddy weld them on next time my car is in his garage.
[Re: mikemee1331]
#2015427
02/19/16 02:10 PM
02/19/16 02:10 PM
Texas383
Marshall TX
awesome and thanks for the reply! are you happy with them?
Quite happy. I bolted mine in originally then had someone weld them later. You want the car to be as level and straight as possible when they get welded. It gave the car more stability.
