MSD 6AL & Blaster 2 with MP distributor #2007338
02/07/16 01:58 PM
02/07/16 01:58 PM
North Central, Indiana
Roughbird72 Offline OP
I've been running the 6AL, Blaster 2 coil without a ballist resistor & MP electronic distributor for a number of years. I replaced one coil 9-10 years ago & now i believe i have another going bad, Should i be running a ballist resistor? shruggy
Jeff
72 Plymouth Roadrunner 11.08@123.25
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2007380
02/07/16 03:00 PM
02/07/16 03:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
No........not w/MSD...........
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2007396
02/07/16 03:34 PM
02/07/16 03:34 PM
midwest
superchuck Offline
On thin ice
superchuck  Offline
On thin ice
midwest
9 or 10 years ago your MSD blaster 2 coil was made in Mexico. 5 or so years ago they started making them in China.
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Thumperdart] #2007405
02/07/16 03:56 PM
02/07/16 03:56 PM
Ok, thanks
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2007977
02/08/16 04:17 PM
02/08/16 04:17 PM
post what is going on
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2007986
02/08/16 04:28 PM
02/08/16 04:28 PM
Occasional miss,popping thru the exhaust & dies sometimes.
I've replaced the cap, rotor & plugs.
It's doing the same thing it did when the last coil was replaced with this one.
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2008037
02/08/16 05:39 PM
02/08/16 05:39 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Current canister type Blaster 2's are junk. I broke the terminal on mine barely tightening down the screw on the positive lead.
I use the old MSD 6AL, Chrysler distributor with quicker curve and an older Chrysler coil. No ballast resistor.
Re: MSD 6AL & Blaster 2 with MP distributor [Re: GY3] #2008105
02/08/16 07:16 PM
02/08/16 07:16 PM
dogdays Offline
dogdays  Offline
You guys are killing me with all this ignition talk.
Why run a canister coil unless it's a restoration or the like? The E-core coils are more efficient and they're everywhere.
It's been at least 30 years!!!!! since MSD published the first wiring diagram for Mopar electronic distributor. Surely this simple diagram can be found and followed.
R.
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2008223
02/08/16 10:40 PM
02/08/16 10:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My Blaster coil which has been in for like 15 years did pretty much the same.I found a small burn hole on the tower.Needed the car running so I heated the outside with soldering iron and pushed some material in the hole.I ran it for a month last summer.Ill replace it this spring when I awaken the 65.Rocky
Chrysler Firepower
Re: MSD 6AL & Blaster 2 with MP distributor [Re: Roughbird72] #2008412
02/09/16 04:15 AM
02/09/16 04:15 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I know all the MSD units I have installed has both coil primary wires come right from the MSD box. So even if you leave the ballast hooked up it wont be feeding anything. The MSD should get a 12 volt key on wire that needs power when cranking also. Then the 2 primary wires to the coil and two wires to the dist pick-up if using that style dist and the two heavy black and red wires go right to the battery. Ron
Re: MSD 6AL & Blaster 2 with MP distributor [Re: 383man] #2008602
02/09/16 03:53 PM
02/09/16 03:53 PM
Detroit, MI
kz5rt2 Offline
kz5rt2  Offline
Detroit, MI
Just out of curiosity, what is the easiest way to get the run/start wire to the ignition box?
Re: MSD 6AL & Blaster 2 with MP distributor [Re: kz5rt2] #2008619
02/09/16 04:16 PM
02/09/16 04:16 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
On my '63 330, I used the factory harness and connected the blue wire in the harness to the run/start wire in the MSD box.
My MSD 6AL is mounted under the battery and you really can't see it unless you look really hard.
