68 Pickup six to 440 swap #2006560
02/06/16 05:06 AM
02/06/16 05:06 AM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
My buddy has a 68 Dodge pickup. Two wheel drive six cylinder that he wants to put a 440 in. I see that Schumacher sells a motor mount kit for this which will help. I always tend to do stock everything when restoring cars so a modification is uncharted territory.
Trying to understand the extent of what I would be getting myself in to. It is a stock truck as it sets. Hoping the drive train can go in without to many modifications. Also hoping the stock diff in the old rig is tough enough for the application.
At this point I have not yet seen the truck in person and am just trying to understand just what all should occur to pull off the modification successfully.
Any insight would be appreciated!
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2006639
02/06/16 12:21 PM
02/06/16 12:21 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
a 383 was an available option in that truck. So putting in a 440 isn't too far off the restoration aspect of your skill set.
Truck probably has an 8 3/4 in it anyway so that should be ok. Don't know what it has for a trans, but if it's a stick then it'll be the NP435 and that will handle the 440, with the right bell housing of course.
Don't be the exception.
Re: 68 Pickup six to 440 swap [Re: Supercuda] #2006722
02/06/16 01:56 PM
02/06/16 01:56 PM
I have a 65 D100 /6 3 speed on column 8&3/4. this is a hyd clutch setup. I have BB OE mtr mts for it and it takes a front sump pan and I am going to Iowa in several hours to pickup a granny 4 sp/hyd clutch BB bellhousing complete setup for it. If going with a 727 there is a bolt in OE crossmember available and speedway mtrs has aftermarket crossmembers that slip in to a bolt in end piece on each side for a pretty easy fab. I believe your truck needs a REAR sump BB pan. I have one for you & the pickup I believe is still with it.
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2006800
02/06/16 04:03 PM
02/06/16 04:03 PM
AndyF Offline
AndyF  Offline
Should be a bolt in with the correct parts. Need a truck pan, truck motor mounts, and maybe the truck exhaust manifolds. I had a BB truck a long time ago. I think mine was a '70 but most of the parts would've been similar to a '68. There is a truck forum on here which is probably the better place to ask.
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008136
02/08/16 07:59 PM
02/08/16 07:59 PM
Maple Valley, WA
70mopes Offline OP
70mopes  Offline OP
Maple Valley, WA
I was thinking of using the truck forum but there is so much knowledge in the General Q&A, I thought I'd give this a shot.
The truck is a 67 actually. He brought it over yesterday. 8 3/4 rear like SupeCuda said so that's good. It's an original slant six, auto with the shifter on the dash - which I believe is a cable setup straight back to the trans?
I would assume a driveshaft would have to be made for it when going with BB and 727?
It is a manual steering, drum brake truck. He asked me yesterday to make it into a power steering, disc brake setup. Man.... I have some 68-73 power steering gears in my shop, would those work? I have a 70 A-body power steering pump as well and was wondering about running that.
The Disc Brake mod.... I really don't know where to start there...
Rapid Robert, if you have that pan and pickup and it will also work on a 67, I would be happy to make a deal with you on them. Thanks for the offer.
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008191
02/08/16 10:01 PM
02/08/16 10:01 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Good Sweptline site
http://www.sweptline.org/forums/index.php
Power steering is a challenge on these trucks. The factory setup used an assist cylinder with a control valve incorporated into the drag link. Hard to find, prone to leaks and costly and difficult to rebuild.
There used to be a couple of kits that used either a Ford or Toyota 4x4 box but I think they're out of production.
Scarebird has a bracket kit to put discs on the straight axle.
https://scarebird.com/index.php?route=product/product&path=64&product_id=117
Some guys swap the cab onto a 73-93 frame which will solve the problem but lots of work.
Another way is to just use the 73-93 front clip.
If I was doing one I would use an 04 and up cop spec Crown Vic clip. This gets you rack and pinion, big brakes and a suspension that is designed for a heavier vehicle that needs to handle well.
Kevin
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008237
02/08/16 10:58 PM
02/08/16 10:58 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Somebody please correct me if I'm wrong, but I'm sure rear sump pans are '72 and newer, front sump '71 and older.
Re: 68 Pickup six to 440 swap [Re: vdriver] #2008256
02/08/16 11:12 PM
02/08/16 11:12 PM
Yeah me too as I have a '65 and a rear sump on the shelf & if I got it straight (somewhere I recently read it) that I need to get a front sump for my 440 swap into it. if it does take a rear sumper I'm happy
Re: 68 Pickup six to 440 swap [Re: RapidRobert] #2008292
02/08/16 11:51 PM
02/08/16 11:51 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
A member here bought my 68 D100 stepside that was a slant 3-speed and he put a 440 in it, something I always wanted to do! It is an easy swap, but you will need to get a 69-71 trans crossmember. I have a factory 69 D200 383 truck and there is plenty of room to play. up
JB Rhinehart, Realist
A-Body's RULE!
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008329
02/09/16 12:41 AM
02/09/16 12:41 AM
Yeah first we gotta find out which sump we both need (65 D100 here) & let me check if I have the pickup with it, I thought I did but let me check (too many projects going on at the same time OCD)
Re: 68 Pickup six to 440 swap [Re: RapidRobert] #2008512
02/09/16 01:15 PM
02/09/16 01:15 PM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
You def need rear sump pan, pickup and dip stick. I made my motor mounts but you can use factory ones if you can find.
I have a picture, but can't seem to find how to add attachments?
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: 68 Pickup six to 440 swap [Re: shaker340] #2008616
02/09/16 04:10 PM
02/09/16 04:10 PM
dogdays Offline
dogdays  Offline
Well, my 64 318 uses a front sump oil pan, FWIW.
The frames up to 1968 are different than the later ones. What worked in a '71 may not work in a '67.
The power steering is difficult to say the least. The factory power steering is junk, also takes up so much room in the wheelwell.
The front clip from a '73 or later ishas been done.
The Crown Vic/Grand Marquis/Town Car 2003 and up IFS setup is the slickest and probably easier than trying to adapt PS to the solid front axle.
R.
Re: 68 Pickup six to 440 swap [Re: dogdays] #2008637
02/09/16 04:29 PM
02/09/16 04:29 PM
Eastern Ontario
shaker340 Offline
shaker340  Offline
Eastern Ontario
Just to clarify, my 64 truck has Rod Weimer mustang 2 style front K frame and suspension, requiring any front sump pan to be converted to rear. If the truck still has solid axle, there may be room for front sump on BB engines.
Re: 68 Pickup six to 440 swap [Re: RapidRobert] #2008663
02/09/16 05:08 PM
02/09/16 05:08 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
I have a 69 crew cab /6 4 speed I converted to power steering and from what I found in my research, and what I did was the "early Toyota 4x4 box conversion" (from a solid axle Toyota truck) I had to re cut the hole in the frame ( now looks like an 8),welded a bracket to the frame for 4 bolts, weld up the upper portion of the Toyota pitman arm to the lower of the dodge one and bolt it in place the rag joint is the same size and the column only needed loosened and shifted slightly. used a mopar ps pump and got lines with compression fittings to hook to the pressure side of the old Toyota lines.
In a descent shop uninterrupted it would have been a 1 day conversion.
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008664
02/09/16 05:08 PM
02/09/16 05:08 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
It would have been much easier with the engine out!
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2008665
02/09/16 05:10 PM
02/09/16 05:10 PM
Des Moines IA
Soopernaut Offline
Soopernaut  Offline
Des Moines IA
CPP makes a bolt in power steering kit. Scarebird and a few other sources have a disc brake kit. You will probably have room to use either a front or rear sump pan. They were all front originally.
1970 Dodge d100/eventually going on a 77 D100 frame
Re: 68 Pickup six to 440 swap [Re: Soopernaut] #2008830
02/09/16 09:57 PM
02/09/16 09:57 PM
I found mine today & it is a front sump, not sure if any of the several pickups I have is the right one for it. If it turns out you need the front sumper (& I dont) then I will mock em up & see if one of em is the correct one for that front sump pan (I'm drilled/tapped to 1/2 NPT so I wouldn't need/use an OE front sump pickup IF I have one). 65 D100 451
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2009191
02/10/16 01:19 PM
02/10/16 01:19 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
This is a front sump tube.
Re: 68 Pickup six to 440 swap [Re: 70mopes] #2009198
02/10/16 01:34 PM
02/10/16 01:34 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Rear sump tube.
Re: 68 Pickup six to 440 swap [Re: vdriver] #2009215
02/10/16 02:02 PM
02/10/16 02:02 PM
Vdriver thank you! I'll do some more checkin today
