Race fuel choice #2006373
02/05/16 11:24 PM
02/05/16 11:24 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Need to pick up some fuel for Dyno testing. What would be a good fuel for 410 SB with 13.3:1 compression run in the 7000rpm range. I'm interested in the VP c12, but not sure this would be a good choice.
Re: Race fuel choice [Re: mopar dave] #2006377
02/05/16 11:30 PM
02/05/16 11:30 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
That`s a real good fuel.........
Re: Race fuel choice [Re: mopar dave] #2006378
02/05/16 11:31 PM
02/05/16 11:31 PM
I would buy a five gallon bucket each of C10 and C12 and see which one makes the most torque and HP up Are you planning on optimizing the jetting? I've been told by some very serious and successful drag racers to use the lowest possible octane that the motor will run on without detonation or pre ignition up More heat (BTU) per gallon in the lower octane according to them work Keep in mind that the spark plug heat range, total ignition timing, compression ratio and jetting all need to be at there very best, optimized, to up to get the best results thumbs scopeGood luck, let us know your results.
Re: Race fuel choice [Re: mopar dave] #2006379
02/05/16 11:31 PM
02/05/16 11:31 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
The VP 112 is what I ran in that 13.3 ish to 1 W5 motor. 7500 at the stripe most passes, never any issue.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Race fuel choice [Re: mopar dave] #2006382
02/05/16 11:33 PM
02/05/16 11:33 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
I buy aviation (avgas) under the table from a guy that has planes in 44 gal drums, about 25% of the price of race fuels.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Race fuel choice [Re: mopar dave] #2006459
02/06/16 01:27 AM
02/06/16 01:27 AM
MR_P_BODY Offline
MR_P_BODY  Offline
That doesnt say anything Dave... you know the cam
is what says it will need(when the valve closes)
wave
Re: Race fuel choice [Re: MR_P_BODY] #2006520
02/06/16 03:33 AM
02/06/16 03:33 AM
Mt Morris Michigan
Mt Morris Michigan
didn't think about that. intake opens at 31.5 and closes at 55.5.
Re: Race fuel choice [Re: ozymaxwedge] #2006523
02/06/16 03:35 AM
02/06/16 03:35 AM
Mt Morris Michigan
Mt Morris Michigan
yeah, but that's 100LL. don't think that's enough octane.
Re: Race fuel choice [Re: mopar dave] #2006566
02/06/16 05:24 AM
02/06/16 05:24 AM
If my memory is half way correct, its been a long time since I have bought VP race gas, I think C10 ia 110 octane and C12 is 112 octane. Both have a different burn rate so they may be close to each other with the same jetting and timing, the final tuning on the dyno will tell you which is best for your motor thumbs IHTHs
Re: Race fuel choice [Re: Cab_Burge] #2006640
02/06/16 12:21 PM
02/06/16 12:21 PM
Mt Morris Michigan
Mt Morris Michigan
vp110 is called vp110 and is 110 octane(107 motor octane). c10 is unleaded and 96 motor octane. c12 is 112 octane(108 motor octane) and im told my engine with run cooler on the c12. vp110 is good to 13:1 compression and the c12 is good to 15:1.
Re: Race fuel choice [Re: mopar dave] #2006662
02/06/16 12:57 PM
02/06/16 12:57 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Once you get it on the dyno, do a compression
check... this will give you a good idea what
fuel
wave
Re: Race fuel choice [Re: MR_P_BODY] #2006673
02/06/16 01:10 PM
02/06/16 01:10 PM
Mt Morris Michigan
Mt Morris Michigan
I bet its aleast 120#. didn't change the cam but 7* dur. same lift and LDA and had 200-205 with 11.3:1 static. now two points higher.
Re: Race fuel choice [Re: mopar dave] #2006679
02/06/16 01:17 PM
02/06/16 01:17 PM
Az
Crizila Offline
Crizila  Offline
Az
Latest Hot Rod has a real good article ( VP question and answer forum)on this. Believe C12 is their biggest seller. Article might help guide you in the right direction. Pretty complicated subject involve many facets. A lot of different ways to get the octane #. The question is which one is right for you. What sticks in my mind most after reading it is the inconsistency of pump gas. beer
Fastest 300
Re: Race fuel choice [Re: Crizila] #2006691
02/06/16 01:29 PM
02/06/16 01:29 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
We tested many fuels at Pettis from stockers to blown and nos stuff and for what you and others are doing in that comp. range the 112 was better overall. I put ZERO stock in cranking this and that and low comp. stockers ran better and that fuel has some excellent properties that go beyond just the octane numbers.......
Re: Race fuel choice [Re: Crizila] #2006693
02/06/16 01:30 PM
02/06/16 01:30 PM
Mt Morris Michigan
Mt Morris Michigan
i'll pick that up while im out today. thanks
Re: Race fuel choice [Re: Thumperdart] #2006698
02/06/16 01:34 PM
02/06/16 01:34 PM
Mt Morris Michigan
Mt Morris Michigan
been reading some reviews on c12 compared to other brands and c12 keeps coming up on top. the shell 110 advantage URT was some bad ass fuel, but from what i understand isn't available anymore.
Re: Race fuel choice [Re: mopar dave] #2007033
02/06/16 11:04 PM
02/06/16 11:04 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
At the track we changed from Avgas 100 to VP110 and the car (12.5-1 RB) ran identical numbers so we stayed with the cheaper .
1971 Barracuda
Re: Race fuel choice [Re: ozymaxwedge] #2007053
02/06/16 11:32 PM
02/06/16 11:32 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I ran AV gas when I was 13-1, so I know it works well. But if you would prefer to buy the expensive VP stuff to feel better about it, enjoy!
Re: Race fuel choice [Re: mopar dave] #2007078
02/07/16 12:12 AM
02/07/16 12:12 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Don't let the cat out of the bag boys, lets keep the 100ll to ourselves, k? Let him run what he wants =$$$$$$$. wink
Mo' Farts
Moderated by "tbagger".
Re: Race fuel choice [Re: ozymaxwedge] #2007083
02/07/16 12:21 AM
02/07/16 12:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
110 is ok at best in a lot of applications........
