Re: Race fuel choice
[Re: mopar dave]
#2006377
02/05/16 11:30 PM
02/05/16 11:30 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
That`s a real good fuel.........
[Re: mopar dave]
#2006378
02/05/16 11:31 PM
02/05/16 11:31 PM
Posts: 43,173 Bend,OR USA
Cab_Burge
I would buy a five gallon bucket each of C10 and C12 and see which one makes the most torque and HP Are you planning on optimizing the jetting? I've been told by some very serious and successful drag racers to use the lowest possible octane that the motor will run on without detonation or pre ignition More heat (BTU) per gallon in the lower octane according to them Keep in mind that the spark plug heat range, total ignition timing, compression ratio and jetting all need to be at there very best, optimized, to up to get the best results Good luck, let us know your results.
[Re: mopar dave]
#2006379
02/05/16 11:31 PM
02/05/16 11:31 PM
Posts: 11,711 Portage,michigan
B3422W5
Portage,michigan
The VP 112 is what I ran in that 13.3 ish to 1 W5 motor. 7500 at the stripe most passes, never any issue.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: mopar dave]
#2006382
02/05/16 11:33 PM
02/05/16 11:33 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
I buy aviation (avgas) under the table from a guy that has planes in 44 gal drums, about 25% of the price of race fuels.
1963 Plymouth Max Wedge 1971 Barracuda
[Re: mopar dave]
#2006459
02/06/16 01:27 AM
02/06/16 01:27 AM
Posts: 52,972 Romeo MI
MR_P_BODY
Need to pick up some fuel for Dyno testing. What would be a good fuel for 410 SB with 13.3:1 compression run in the 7000rpm range. I'm interested in the VP c12, but not sure this would be a good choice. That doesnt say anything Dave... you know the cam is what says it will need(when the valve closes)
[Re: mopar dave]
#2006566
02/06/16 05:24 AM
02/06/16 05:24 AM
Cab_Burge
If my memory is half way correct, its been a long time since I have bought VP race gas, I think C10 ia 110 octane and C12 is 112 octane. Both have a different burn rate so they may be close to each other with the same jetting and timing, the final tuning on the dyno will tell you which is best for your motor IHTHs
[Re: mopar dave]
#2006662
02/06/16 12:57 PM
02/06/16 12:57 PM
MR_P_BODY
didn't think about that. intake opens at 31.5 and closes at 55.5. Once you get it on the dyno, do a compression check... this will give you a good idea what fuel
[Re: mopar dave]
#2006679
02/06/16 01:17 PM
02/06/16 01:17 PM
Posts: 7,506 Az
Crizila
Az
Need to pick up some fuel for Dyno testing. What would be a good fuel for 410 SB with 13.3:1 compression run in the 7000rpm range. I'm interested in the VP c12, but not sure this would be a good choice. Latest Hot Rod has a real good article ( VP question and answer forum)on this. Believe C12 is their biggest seller. Article might help guide you in the right direction. Pretty complicated subject involve many facets. A lot of different ways to get the octane #. The question is which one is right for you. What sticks in my mind most after reading it is the inconsistency of pump gas.
Fastest 300
[Re: Crizila]
#2006691
02/06/16 01:29 PM
02/06/16 01:29 PM
Thumperdart
State of confusion
Need to pick up some fuel for Dyno testing. What would be a good fuel for 410 SB with 13.3:1 compression run in the 7000rpm range. I'm interested in the VP c12, but not sure this would be a good choice. Latest Hot Rod has a real good article ( VP question and answer forum)on this. Believe C12 is their biggest seller. Article might help guide you in the right direction. Pretty complicated subject involve many facets. A lot of different ways to get the octane #. The question is which one is right for you. What sticks in my mind most after reading it is the inconsistency of pump gas. We tested many fuels at Pettis from stockers to blown and nos stuff and for what you and others are doing in that comp. range the 112 was better overall. I put ZERO stock in cranking this and that and low comp. stockers ran better and that fuel has some excellent properties that go beyond just the octane numbers.......
[Re: mopar dave]
#2007033
02/06/16 11:04 PM
02/06/16 11:04 PM
ozymaxwedge
Australia
At the track we changed from Avgas 100 to VP110 and the car (12.5-1 RB) ran identical numbers so we stayed with the cheaper .
[Re: ozymaxwedge]
#2007083
02/07/16 12:21 AM
02/07/16 12:21 AM
Thumperdart
State of confusion
At the track we changed from Avgas 100 to VP110 and the car (12.5-1 RB) ran identical numbers so we stayed with the cheaper . 110 is ok at best in a lot of applications........
