Page 2 of 5 1 2 3 4 5
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2005909
02/05/16 02:22 AM
02/05/16 02:22 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I bought this pos and muddled through the set up on three sets of 8.75 gears..... shoot me an address and I'll send it your way. From my memory of using it.... I'm not sure this is a threat, or a promise.
http://www.proformparts.com/product-exec...category_id/159
...at least at work we still have all the dummy bearings etc for the D60 stuff.
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2005912
02/05/16 02:28 AM
02/05/16 02:28 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
You DON'T need high tech tools to do this. Aftermarket gears have the depth measurement marked on them. This number is the measured distance from the machined surface of the pinion gear head, to the centerline of the ring gear. Common sense tells you that the ring gear centerline, is also at the parting line of the caps. So my "trick" pinion setting tool is a precision straight edge and a set of dial calipers. Lay the straight edge across the carrier, place dial caliper on top of straight edge.....roll the caliper until the "tail" contacts top of pinion gear. Read that number, subtract width of straight edge(mine is exactly 1") and there you have it. This and a set of honed bearings is ALL you need.
Now, I have had people tell me the cap parting line is not always "true" center of ring gear, because of casting variance. Ok, I have never seen this to be true, but lets say it is. You can STILL use the straight edge method. It will be really close and you are going to put it together, check the pattern and make adjustments anyway, so what does it matter. This is NO different than guessing at a shim pack you have and checking it, although this will likely be closer from jump, unless you get lucky on the guess.
If you just WANT to buy a tool, but not break the bank. Try the Ratech tool. They are cheap, about 30 bucks and actually work. Look it up. Little different approach, but they work
Re: SETTING PINION DEPTH............ [Re: J_BODY] #2005913
02/05/16 02:36 AM
02/05/16 02:36 AM
State of confusion
Thumperdart Offline OP
State of confusion
Why don`t you like or need it?
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2005920
02/05/16 02:58 AM
02/05/16 02:58 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
it was many moons ago that I used it to set up a few 8.75 gear sets.... as I remember it just seemed a bit confusing trying to use it. We have all set up tools for D-60 rears at work so that makes it easy for my present configuration.
Re: SETTING PINION DEPTH............ [Re: Monte_Smith] #2005921
02/05/16 02:59 AM
02/05/16 02:59 AM
State of confusion
State of confusion
Ya Monte, a gentleman on here told me the parting line was how he does em and it`s good enuff for me but having the trick tools probably can`t hurt........... thumbs
Re: SETTING PINION DEPTH............ [Re: Monte_Smith] #2005929
02/05/16 03:14 AM
02/05/16 03:14 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Dom, What Monte describes here is EXACTLY what I was trying to describe on the phone.
Re: SETTING PINION DEPTH............ [Re: StealthWedge67] #2005932
02/05/16 03:24 AM
02/05/16 03:24 AM
State of confusion
State of confusion
You are who I was talking about sir........ thumbs
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2005979
02/05/16 09:19 AM
02/05/16 09:19 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used to use the parting line method. The line was not always in the middle but easy to compensate for. Just measure the caps and the housing. Add the results and split the difference. Add or subtract the result of the split to the carrier. Like everyone has said you need to read the pattern anyway so now I just start with the old shim.
Doug
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006089
02/05/16 02:53 PM
02/05/16 02:53 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
In this instance, there is no "old" shim, because this is a totally new setup. Says he is selling old unit complete. So you either guess at a shim, or put it in with nothing and check depth. Adjust to depth scribed on pinion, put it together, check pattern.
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006106
02/05/16 03:09 PM
02/05/16 03:09 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
As per Richmond's instructions - Shim thicknesses to start with, Dana’s .035, 8-3/4 x 1-3/4 pin, .090, 8-3/4 x 1-7/8 pin, .020, These have worked for me in the past to get me started, MOST of the time.
Re: SETTING PINION DEPTH............ [Re: dvw] #2006109
02/05/16 03:14 PM
02/05/16 03:14 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Doug
This is quite correct,when using the parting line first measure the depth of the bearing seat(apex of the radius of half the bore) then devide the total radius by 1/2.ie: a Dana bearing race measures 3.813 devided by 2 equals 1.9065,if the housing depth measures 1.881 ,this tells us the housing part line surface is machines .025 below the true bearing centerline and we must add .025 to correct our pinion depth.
We have and use all the fancy tools,but in the end we do what ever to obtain the best pattern and clearance which is the most important thing.
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006111
02/05/16 03:15 PM
02/05/16 03:15 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Start with a 0.040" shim.
Re: SETTING PINION DEPTH............ [Re: DoctorDiff] #2006115
02/05/16 03:25 PM
02/05/16 03:25 PM
State of confusion
State of confusion
Thankxxx guys...........Cass, was going to call you and see what you recommended as a starting shim since these are your cases and a new design if it mattered............ thumbs Will be ordering 35 spline axles next week. Do you carry lug nuts and washers?
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006125
02/05/16 03:32 PM
02/05/16 03:32 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Originally Posted By Thumperdart
Originally Posted By GTX MATT
Thumper RA Tech sells pinion depth checkers that are less than 300 bucks, they sit between on the pinion head and you measure against the carrier bores a certain way to check depth, using the depth indicator on a pair of veneer calipers.
I just bought one to use on my 8 3/4. I'm sure it won't be perfect, but will give you a good start, then adjust based on the pattern. People with the high dollar mics say they often need to adjust based on the pattern anyway, as the depth from the manufacturer isn't quite perfect. You can buy the tool on summit and they're application specific. Reviews on them have been pretty good.
http://www.summitracing.com/parts/rat-10007/overview/
You said $300 bucks that thing`s 25 and change and if it helps, it may be a new tool in my box......... thumbs
Sorry Thump it was a typo, I meant $30.
I set my last one up guessing and checking, which gets a little annoying to keep setting the backlash precisely the same. I figured this should ball park me closer to start like I said. Especially doing it for the first time, it gets a little fuzzy with depth vs backlash and what it does to the pattern when you start really far off.
Re: SETTING PINION DEPTH............ [Re: GTX MATT] #2006129
02/05/16 03:45 PM
02/05/16 03:45 PM
State of confusion
State of confusion
No biggie, I`m going to vatozone soon and will get a bearing, hone it and start checking............ thumbs
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006135
02/05/16 03:48 PM
02/05/16 03:48 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Unfortunately, I don't carry lug nuts.
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006139
02/05/16 03:57 PM
02/05/16 03:57 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
This is the hardest part of the job.
What's everyone using for backlash? IIRC my last Richmond set called for .006-.010, I set it up at .010, they were smooth but they hummed over 55 (4.56s). I set them up loose hoping they wouldn't break easy, but I broke them anyway, so I think I'm going to try the tight side this time.
Re: SETTING PINION DEPTH............ [Re: DoctorDiff] #2006140
02/05/16 03:59 PM
02/05/16 03:59 PM
State of confusion
State of confusion
No problem I`ll get em locally. GTXMatt, Cass suggested .007 so I`ll shoot for that which apparently meshes better to avoid breakage..........
Re: SETTING PINION DEPTH............ [Re: Thumperdart] #2006144
02/05/16 04:12 PM
02/05/16 04:12 PM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
As mentioned, the Ratech gauge works great http://www.summitracing.com/parts/rat-10007/overview/
The setup bearings will get you close, but set the shims on the loose side because the actual pressed on bearing will expand slightly from the press fit.
The clamshell type bearing remover will allow you remove the bearings without damage if you need to change the shims.
http://www.ebay.com/itm/DIFFERENTIAL-BEA...r-/251544641906
If you need a case spreader for a Dana 60
http://www.ebay.com/itm/Differential-Housing-Case-Spreader-Dana-30-80-Housings-New-/351606418157?hash=item51dd602aed:g:vDMAAOSwCQNWcf1u&item=351606418157&vxp=mtr
Re: SETTING PINION DEPTH............ [Re: 451Mopar] #2006150
02/05/16 04:28 PM
02/05/16 04:28 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
I have that tool and it works great for side bearings. On the pinion bearings, I prefer to polish the journals on the pinion to get the fit I prefer; light enough that I can get the bearing on and off without damaging it. Light enough on the front bearing that it will go in and out with a light mallet. Then you're able to set it up with the bearings you're going to use. I find the bearing fit on new pinions to be all over the place depending on who made them. Some just need the coating polished off, others require more work for an acceptable fit. Tolerances seem to be all over the place on these parts these days.
