largest tire wheel on a 72 rr with mini tub and relocation?
#1987066
01/09/16 07:22 PM
01/09/16 07:22 PM
Posts: 46 texas
462hemi
texas
i have done some reading and it looked like someone on the tubbed thread was saying something about fitting a 15x14 rear wheel on a 72 road runner with a mini tub and the springs relocated to the framewell......can anyone confirm or correct this? what is the largest wheel/tire combo possible?
462 gen 3 hemi daily driven
Re: largest tire wheel on a 72 rr with mini tub and relocation?
[Re: 462hemi]
#2005663
02/04/16 08:52 PM
02/04/16 08:52 PM
Posts: 46 texas
462hemi
texas
anyone have any input here? surely some of you guys have done this before. any input at all would be helpful
[Re: 462hemi]
#2005805
02/05/16 12:02 AM
02/05/16 12:02 AM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Have 295 width on a 72 Charger with springs relocated, no sheet metal work with an inch on each side. 12" cross section width on 10" wheels. Backspacing is critical.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: 462hemi]
#2006369
02/05/16 11:18 PM
02/05/16 11:18 PM
Posts: 17,925 Akron, Ohio
ProSport
Akron, Ohio
Steve88, your car looks incredible!
My Dad had a 340 '71 RR, he ran a good sized McCreary tire on the back with no modifications, it's amazing how much tire will fit on these B-bodies.
[Re: 462hemi]
#2006689
02/06/16 01:26 PM
02/06/16 01:26 PM
Posts: 570 USA
Hooligan
USA
Well, if no one chimes in with an example that satisfies your question, just do what I did. Pick the tire and wheel combo that you want, and get their specs on the internet. Tirerack.com is a good choice, and for the wheels, search the manufacturer's website. Then you can make cardboard templates to position in your wheel wells... taking into account, any modifications to the tubs and leaf springs that you want to make, and suspension travel. If the combo that you chose is too large, pick another until you find one that fits just right. It's easy to do. Some company sells an adjustable gizmo that bolts to your axle for mock ups, but if you are only doing this one time, save your money. Sounds like I know what I am talking about, doesn't it?
